Date/Time: Wed, 22 Jan 2025 06:49:02 +0000
DOM - best bids/offers
View Count: 708
[2018-09-17 16:20:51] |
kerobo0000 - Posts: 4 |
Thank you for extending the trial. When viewing the DOM, it doesn't show the next 10 best bids/offers - only the one best bid and one best offer. Could this be due to an account setting? Is there anything you can do to help? I've restarted Sierra Charts & broker platform and have also disconnected and reconnected to the data feed. Any help you can provide will be helpful. thank you
[2018-09-17 18:01:33] |
You should be seeing 10 levels of market depth. Tell us the symbol you are looking at. And make sure the Low Bandwidth option is disabled: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#LowBandwidthOption Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-17 19:08:53
