Date/Time: Wed, 22 Jan 2025 06:57:02 +0000
LMAX Trading
View Count: 606
[2018-09-17 14:20:39] |
User138602 - Posts: 169 |
Hello, Quote: "Otherwise, you need to have a Live or Demo account with LMAX. You will need a standard LMAX Web Client or API account. Either one will work. You can have an account directly with LMAX or through one of their Introducing Brokers." Does this mean i can have Sierra Chart_Charttrading via ANY!!! Introducing LMAX-Broker? Best Regards |
[2018-09-17 17:05:20] |
Yes there should not be a problem with this as long as you have an account which exists directly on the LMAX system.
