Date/Time: Wed, 22 Jan 2025 07:00:55 +0000
Data Services
View Count: 615
[2018-09-17 12:43:46] |
User286244 - Posts: 3 |
I have a funded account through Interactive Brokers. Currently I am paying $35 + $3.25. I day-trade mostly the ES but also want access to NQ and SC (Russell). It looks to me like there are cheaper options?
[2018-09-17 12:52:57] |
SC Support - Posts: 1917 |
Hi there, Just to clarify, are you speaking about a cheaper option at Sierra Chart, that gives you access to ES, NQ, and SC? Or do you mean that there is a cheaper option to Sierra Chart? Thank you |
[2018-09-17 14:02:23] |
I am happt with Sierra Charts. I am looking for a cheaper data feed to use as the current one is $35 and $3.25 and gives me 100 symbols. I have seen one at $15.75 but am not sure if it will give me the feed I need for day-trading those few symbols I mentioned.
[2018-09-17 14:20:56] |
The data feed is the most significant challenge for clients, indeed for the industry; I believe that there is no cheaper method for data than what you have currently. I will double check that this is so, and get back to you if I am wrong. Thank you
[2018-09-17 15:35:23] |
Thanks, I will check it.
[2018-09-17 17:15:13] |
Thank you 40winks, User286244 that is correct, you can do choose the 20 symbol option. Thank you. Reference: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing Date Time Of Last Edit: 2018-09-17 17:32:16
