Date/Time: Wed, 22 Jan 2025 06:43:33 +0000
Release Compile Error
View Count: 571
[2018-09-17 12:10:21]
User572956 - Posts: 7
Hello, after updating to version 1806 there is a compilation error
-- Starting remote build of Custom Studies Source files: S1.cpp. 64-bit -- 17:07:13
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
In file included from scstructures.h:84:0,
from sierrachart.h:15,
from S1.cpp:1:
SCString.h: In constructor 'SCString::SCString(const char*, int)':
SCString.h:201:41: error: 'min' was not declared in this scope
StringLength = min(Length, MAX_LENGTH);
SCString.h:201:41: note: suggested alternative:
In file included from /usr/lib/gcc/x86_64-w64-mingw32/5.3-win32/include/c++/algorithm:62:0,
from scstructures.h:49,
from S1.cpp:1:
/usr/lib/gcc/x86_64-w64-mingw32/5.3-win32/include/c++/bits/stl_algo.h:3451:5: note: 'std::min'
min(initializer_list<_Tp> __l, _Compare __comp)
-- End of Build -- 17:07:15
[2018-09-17 12:31:06]
1800 success compile
[2018-09-17 17:57:57]
We are looking into this.
