Date/Time: Wed, 22 Jan 2025 10:08:28 +0000
Form on chart
View Count: 972
[2018-09-17 05:57:34]
User701453 - Posts: 176
SC could you provide a link to example code or documentation as to how to add to a chart.
A form with buttons on it that can control an automated strat (ie long or short only trades, etc)
It can be done some how as a sierra charts user on Youtube video has done it.
See screen shot in regard to better understand what im asking for information on.
imageform on chart.PNG / V - Attached On 2018-09-17 05:55:53 UTC - Size: 442.48 KB - 323 views
[2018-09-17 19:59:43]
Refer to:
ACSIL Programming Concepts: Use of Dialog Windows in Advanced Custom Studies
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events
[2018-09-17 22:04:43]
Thanks..I guess the company that did the chart dialog window has some kind of magic wand to make it work correctly.
[2018-09-17 23:49:26]
It is just a matter of using the right operating system functions and proper programming. We updated this section to provide further details:
But really if you just need a few simple buttons you should use the built-in Control Bar buttons.
[2018-09-18 14:46:31]
Thanks.
I would like to be able to select in which direction (Long,Short,Allow Reverse, etc) I want my strat to trade with just a click of a button.
Not have to dig into the study and locate the input option to change...In a fast market I need to make a decision with a quick click.
