Date/Time: Wed, 22 Jan 2025 06:50:49 +0000
Custom Delta Ladder
View Count: 1405
[2018-09-16 14:59:49] |
User278521 - Posts: 6 |
Hello, I can not find in Custom Studies Delta Ladder studie which is on picture displayed on right sight last bar https://www.sierrachart.com/image.php?Image=1307044599690.png Wherer should I look for this study please? |
[2018-09-17 16:40:14] |
John - SC Support - Posts: 37369 |
That is the Numbers Bars study. You will find the documentation here: Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-17 17:40:48] |
The Delta Ladder study was not in Numbers bars study. Delta Ladder was in separate column of studies than Numbers Bars. The delta Ladder Study was possible to add like only one number bar into all kind of chart include standard bar chart without another number studies. Delta Ladder was in the same column of studies like Breakdown Volume studie for example. But I lost all the 3rd column of studies and I see only two columns /two area/ of studies in last few days. In my Sierra are not displayed all the kinds of studies what I can see at Sierra from another traders. I totaly lost the studies column/area where was Delta Ladder studie, Breakdown Volume studie, Higher High Volume studies etc.
[2018-09-17 18:11:17] |
That is a Custom Study then, and not one that was provided by Sierra Chart, so you would need to determine where you originally received the study from and why it is not available for you anymore. That is not something that we can help with.
