Date/Time: Wed, 22 Jan 2025 10:09:37 +0000
[User Discussion] - How to Color "Bar Difference" Bar According to Closing Price
View Count: 1058
[2018-09-16 12:58:26]
Halco - Posts: 92
For instance if the close of price is lower, "Bar Difference" bar is red; if close is higher, the bar is green. I know this should probably be pretty simple and I assume I would need two studies, one for each color, but I've read the documentation for "Color Bar Based on Alert Condition" and tried various settings and formulas but I can't make it work. Thanks!
[2018-09-17 06:58:33]
Cavalry3162 - Posts: 523
what "various" settings have you tried? can you post examples?
[2018-09-17 18:17:05]
John - SC Support - Posts: 37369
Refer to the following. You need to make sure you have every setting correct as per this documentation in addition to the Alert condition:
Color Bar Based on Alert Condition: Coloring Subgraphs of Other Studies
[2018-09-19 06:10:09]
Halco - Posts: 92
Got it.
Andreas, I was setting Draw Style to "Color Bar" instead of "Bar".
Date Time Of Last Edit: 2018-09-19 06:14:57
