Date/Time: Tue, 04 Feb 2025 01:57:30 +0000
Chart Drawings On 1 Chart Not Visible After Rollover
View Count: 1224
[2018-09-14 19:14:11] |
ged - Posts: 233 |
Rolled over NQ chartbook. All charts rolled over fine except primary trading chart. After rollover all of its drawings are invisible/gone. What is best/quickest method to fix this?
[2018-09-14 19:52:01] |
Refer to: http://www.sierrachart.com/index.php?page=doc/ChangingFuturesContract.html#ChartDrawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-21 13:21:23] |
User164231 - Posts: 278 |
hi I use Extended Rectangle to mark my horizontal level, once contract rolled over they all gone missing. What did I do wrong? Thanks. |
