Date/Time: Wed, 22 Jan 2025 07:08:19 +0000
SC Data ICE europe very slow and not working
View Count: 638
[2018-09-14 17:29:27] |
User210422 - Posts: 19 |
Hi I have SC Data, Today the ICE europe feeds are very slow, and not updating on the dom. I am noticing it particularly in ICE Brent Futures (QOX18). Thansk |
[2018-09-14 17:30:06] |
Okay we will check on this and let Barchart know about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-14 17:44:07
[2018-09-14 17:43:33] |
We do observe the problem and we have notified Barchart about this and that it is a priority issue.
[2018-09-14 19:34:00] |
Letting you know that Barchart did resolve the problem and we will patch the incomplete data over the weekend.
