Date/Time: Wed, 22 Jan 2025 06:56:51 +0000
Trade Service Log - Order Error - CQG Fix:Order type Trade Volume Trigger Stop is not.....
View Count: 698
[2018-09-14 16:25:22] |
User7817001 - Posts: 96 |
Getting an error in Trade Service Log when attempting to place an attached order using Trade Volume Trigger Stop (and yes, CQG) Thoughts? Thanks, Mark |
[2018-09-14 18:10:01] |
We need to see the exact message. Refer to: http://www.sierrachart.com/index.php?page=doc/PostingInformation.php#ProvidingLinesFromTradeServiceLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-14 19:10:17] |
here ya go!
Capture.JPG / V - Attached On 2018-09-14 19:09:54 UTC - Size: 118.26 KB - 278 views |
[2018-09-14 19:37:31] |
This is very unusual. You should not get that error. Is this an attached order?
[2018-09-14 19:40:39] |
We see what the problem is. We are resolving this.
