Date/Time: Wed, 22 Jan 2025 06:52:03 +0000
Level 2 historical tick replay data
View Count: 1731
[2018-09-14 16:15:26] |
User546291 - Posts: 1 |
Hello. Is there a way to download Level 2 tick replay data in the trial account? I use no charts to trade, just the DOM and it would be great to see Level 2 data. Thank you
[2018-09-14 18:35:48] |
Yes this can be done but only for the crypto currency markets. These are the only markets you will get market depth data on during a trial if you have no other real-time data feed you are currently using. Refer to: http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayingOfMarketDepthData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
