Date/Time: Wed, 22 Jan 2025 06:42:04 +0000
Trading system based on alert condition - position definition
View Count: 914
[2018-09-14 05:41:12] |
User958129 - Posts: 1 |
For the life of me I cant find the formula definition for "since my last trade" - or "my last trade entry price" - or " my current position entry price".. You get the idea. If I want to set an Exit stop where price goes too many ticks away from me - how does it know where "I am" ? All the formula definitions and functions refer to High, Low, Close, Lasttrade (which isnt MY last trade), Volume, Time, etc etc.. Where is mylasttrade? Any help appreciated, could be a dumb question |
[2018-09-14 17:48:15] |
You cannot do what you want using that study. You need to use the Spreadsheet System For Trading study instead: http://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
