Date/Time: Wed, 22 Jan 2025 07:00:18 +0000
Bitmex not working by now?
View Count: 689
[2018-09-14 03:20:12] |
User271989 - Posts: 44 |
A dev told me that the api endpoint is not working so he can't make a Bot. He tested with the testnet keys There is anything I can do? |
[2018-09-14 06:36:32] |
You need to use the new BitMex trading direct connection: BitMEX Trading Service BitMex discontinued the old DTC connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
