Date/Time: Wed, 22 Jan 2025 07:05:25 +0000
Manage Chart Drawing Freezing
View Count: 977
[2018-09-13 16:15:55]
CTBSD - Posts: 10
Trying to adjust for rollover is causing Sierra to freeze and only able to unfreeze by task manager. When I open manage chart drawing, then highlight a drawing, then click adjust everything freezes. I am using the most current update.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=21946
[2018-09-13 16:51:45]
Provide the Chartbook you are using and we will test. Here are instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
And tell us the ID number of the particular drawing you are adjusting.
[2018-09-15 11:10:12]
CTBSD - Posts: 10
It seems to only be a issue trying to adjust extending rectangles. Another charts with only lines adjusted perfectly.
[2018-09-15 21:34:16]
We ran a basic test adjusting an extending rectangle and could not reproduce. It would be appreciated if you could provide that particular chart following the instructions here:
You can make the attachment private so only we have access to it.
