Date/Time: Tue, 22 Sep 2026 06:02:44 +0000
HOWTO Convert Time To Seconds ?
View Count: 2399
| [2018-09-13 08:03:09] |
| User574685 - Posts: 28 |
HI, it there some easy way in sierra to convert time to seconds ? For example 1:20:50 = 4850 seconds ........ Thanks Dave Date Time Of Last Edit: 2023-01-01 19:37:14
| [2018-09-13 14:35:09] |
| John - SC Support - Posts: 47955 |
Have a look at this page: Working with the SCDateTime Variables and Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-12-31 18:56:22] |
| TriStar Trading - Posts: 200 |
Here is how I did it. //Set the configuration variables and defaults. SCSubgraphRef BarSeconds = sc.Subgraph[0]; if (sc.SetDefaults) { //Set the configuration and defaults sc.GraphName = "Bar Duration In Seconds; sc.GraphRegion = 1; //Not Main graph region sc.AutoLoop = 1; sc.ValueFormat = 0; //Define the Subgraphs BarSeconds.Name = "Bar Seconds"; BarSeconds.DrawStyle = DRAWSTYLE_BAR; BarSeconds.LineWidth = 2; BarSeconds.PrimaryColor = RGB(128,128,128); return; } SCDateTimeMS BarEndDateTime = sc.GetEndingDateTimeForBarIndex(sc.Index); SCDateTimeMS ElapsedTime = static_cast<float>((BarEndDateTime - sc.BaseDateTimeIn[sc.Index] + SCDateTime::MICROSECONDS(1)).GetAsDouble()); BarSeconds[sc.Index] = ElapsedTime.GetTimeInSeconds(); |
