Date/Time: Wed, 22 Jan 2025 06:48:07 +0000
Order and Position Lines
View Count: 3387
[2018-09-13 05:20:19] |
User439067 - Posts: 48 |
Is there a way to move the order sliders/info boxes over to the right of the screen and remove the lines? Even better would be to make them extend from the left to the last bar. My chart is busy enough as it is and these lines are driving me nuts. I can't see what's going on. Thanks, |
orderlines.PNG / V - Attached On 2018-09-13 05:20:10 UTC - Size: 1.99 KB - 459 views |
[2018-09-13 14:25:39] |
John - SC Support - Posts: 37369 |
Refer to the following documentation along with the 2 sections immediately below it for how to align the Position Lines: Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-13 15:25:42] |
Thank you I was able to find something I liked. It would be super sweet if you could move the boxes right aligned and then have a line extend left 50% etc. I would be my perfect setup. Thanks! |
[2018-09-13 19:44:13] |
All of the available options are explained here: Chart Trading and the Chart DOM: Size and Positioning of Working Orders Lines, Position Line, and Order Fills Displayed On Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
