Date/Time: Wed, 22 Jan 2025 07:04:44 +0000
Help with Setting ---> Right Click Exits Current Drawing Tool
View Count: 761
[2018-09-13 02:58:09]
User62936 - Posts: 68
I saw a post a couple of weeks ago where someone mentioned that this option was removed and you added it back in. I see now this setting available. But when I am using one tool, and then right click, it exits to the pointer tool. I would like the hand tool to be the default. Under the setting "After single use too change to: XXX", I have Hand tool selected, but when I right click to exit a drawing tool, it always goes back to the pointer. How can I set my hand tool to be the default tool?
[2018-09-13 05:08:15]
For this you need to use the latest prerelease:
[2018-09-13 05:41:37]
So I upgraded to 1804, and the right click works as expected for chart drawings and tools. But now I can't right click on the chart and bring up my chart shortcut menu.
Edit: I have to disable the "right click exits current drawing tool" in order to allow for the right click to open the chart shortcut menu.
Date Time Of Last Edit: 2018-09-13 05:47:28
[2018-09-13 06:34:11]
Okay we will look this over.
[2018-09-14 01:25:02]
We now have this solved.
