Date/Time: Wed, 22 Jan 2025 09:57:17 +0000
CL Historical Data
View Count: 1321
[2018-09-12 19:53:07] |
User719035 - Posts: 1 |
I am trying to use the Sierra Chart Historical Data Feed to view live and expired futures contracts so I can download and analyze tick data. I use a different platform to conduct statistical analysis and I want to export this data and import into another platform. I can't seem to get this loaded properly and need help.
[2018-09-13 05:01:45] |
You need to open a chart by following through the instructions here: Sierra Chart Historical Data Service: Setup Instructions And here are the instructions for exporting data: Edit Menu: Edit >> Export Intraday Data to Text file Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-13 05:02:25
[2018-09-19 13:31:35] |
User954352 - Posts: 3 |
I understand the settings but I am unable to download tick data dating back a few years. I read that this was possible using the Sierra Charts data feed, which I paid for. I am trying to gather 2 years of CL tick data and I am unable to get this to populate
[2018-09-20 06:53:43] |
We need to understand this better. You must be able to open a chart and see the data, right?
[2018-09-20 13:41:00] |
Yes, I can open a chart and see the data, but the CL contract will only display intraday tick data for less than a day. It will not download anything beyond even though I have the settings set correctly. I am trying to get about two years of futures tick data so I can perform analysis. Please let me know the best way to move forward. Thanks -a |
[2018-09-20 14:00:51] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-20 14:15:39] |
Reading Internal Order ID file. | 2018-09-20 09:05:07 Reading Trade Orders file. | 2018-09-20 09:05:07 Reading Trade Positions and Account Balance file. | 2018-09-20 09:05:07 Listening on UDP port 22904. | 2018-09-20 09:05:07 Software version: 1798 64-bit | 2018-09-20 09:05:07 Usage end date: 2018-10-13 | 2018-09-20 09:05:07 Enabled for: Advanced Features. | 2018-09-20 09:05:07 Enabled for: Advanced Features 2. | 2018-09-20 09:05:07 Enabled for: Sierra Chart Historical Data Service. | 2018-09-20 09:05:07 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-09-20 09:05:07 Enabled for: INDEXES_DATA_BARCHART | 2018-09-20 09:05:07 Enabled for: CME (Trading Account Required) | 2018-09-20 09:05:07 Enabled for: CBOT (Trading Account Required) | 2018-09-20 09:05:07 Enabled for: COMEX (Trading Account Required) | 2018-09-20 09:05:07 Enabled for: NYMEX (Trading Account Required) | 2018-09-20 09:05:07 Received 1 data feed usernames. | 2018-09-20 09:05:07 Allow Support for Sierra Chart Data Feeds is disabled. | 2018-09-20 09:05:07 Current selected Data/Trading service: SC Data - All Services | 2018-09-20 09:05:07 Chart Update Interval: 500 | 2018-09-20 09:05:07 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-09-20 09:05:07 2018-09-20 09:05:06 Local computer time | 2018-09-20 09:05:07 2018-09-20 14:05:06 Local computer time in UTC | 2018-09-20 09:05:07 2018-09-20 09:05:06 Local computer time in SC Time Zone | 2018-09-20 09:05:07 2018-09-20 14:05:06 Server time in UTC | 2018-09-20 09:05:07 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-09-20 09:05:07 Program path: C:\SierraChart\ | 2018-09-20 09:05:07 Data Files path: C:\SierraChart\Data\ | 2018-09-20 09:05:07 OS Version Number: 10.0 | 2018-09-20 09:05:07 Locale Setting: C | 2018-09-20 09:05:07 Checking for new symbol settings for service code scdataallservices | 2018-09-20 09:05:07 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-09-20 09:05:07 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-09-20 09:05:07 Received 5 login tokens. | 2018-09-20 09:05:08 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-09-20 09:05:09 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-09-20 09:05:09 HTTPS connection to login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-09-20 09:05:11 HTTPS connection to login.sierrachart.com:443 (1) | Received socket Close event. | 2018-09-20 09:05:11 HTTPS connection to login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-09-20 09:05:11 HTTPS connection to login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-20 09:05:11 HTTPS connection to login.sierrachart.com:443 (1) | Closed. | 2018-09-20 09:05:11 SC Data - All Services | Connected to data server. | 2018-09-20 09:05:12 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-09-20 09:05:13 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-09-20 09:05:13 HTTPS connection to www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-09-20 09:05:13 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-20 09:05:13 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-09-20 09:05:13 Symbol settings are up-to-date for scdataallservices | 2018-09-20 09:05:14 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-09-20 09:05:14 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-09-20 09:05:14 HTTPS connection to www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-09-20 09:05:14 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-20 09:05:14 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-09-20 09:05:14 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-09-20 09:05:19 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-09-20 09:05:19 HTTPS connection to www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-09-20 09:05:19 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-20 09:05:19 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-09-20 09:05:19 CLX18 1 Min #1 | Reloading chart. | 2018-09-20 09:05:49 CLX18 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLX18.scid | 2018-09-20 09:05:49 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL?## pattern/symbol will not use the SC Exchange Data Feed. | 2018-09-20 09:05:49 SC Data - All Services | Starting real-time market data updates for: CLX18. ID: 1 | 2018-09-20 09:05:49 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: CLX18 | 2018-09-20 09:05:49 SC Data - All Services | Requesting security definition data for: CLX18. ID: 1 | 2018-09-20 09:05:49 Intraday data recording state for symbol CLX18 is set to download 'Pending'. | 2018-09-20 09:05:49 Delaying start of download for CLX18 | 2018-09-20 09:05:49 HD Request # 2 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:05:55 HD Request # 2 | Download start date-time: 2017-11-24 08:05:54.000 | 2018-09-20 09:05:55 HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2018-09-20 09:05:55 Socket (6) | Creating socket. | 2018-09-20 09:05:55 Socket (6) | Connecting to IP: 8.18.161.133. | 2018-09-20 09:05:55 Socket (6) | Signaling to core to close socket | 2018-09-20 09:06:15 Socket (6) | Closed. | 2018-09-20 09:06:15 HD Request # 2 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:06:15 Historical data download thread signaled to stop. | 2018-09-20 09:06:15 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:06:15 HD Request # 2 | Completion time: 20s | 2018-09-20 09:06:15 HD Request # 3 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:06:15 HD Request # 3 | Download start date-time: 2017-11-24 08:06:14.000 | 2018-09-20 09:06:15 HD Request # 3 | Using server: ds1.sierracharts.com port 10150 | 2018-09-20 09:06:15 Socket (8) | Creating socket. | 2018-09-20 09:06:15 Socket (8) | Connecting to IP: 8.18.161.135. | 2018-09-20 09:06:15 Socket (8) | Signaling to core to close socket | 2018-09-20 09:06:35 Socket (8) | Closed. | 2018-09-20 09:06:35 HD Request # 3 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:06:35 Historical data download thread signaled to stop. | 2018-09-20 09:06:35 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:06:35 HD Request # 3 | Completion time: 20s | 2018-09-20 09:06:35 HD Request # 4 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:06:35 HD Request # 4 | Download start date-time: 2017-11-24 08:06:34.000 | 2018-09-20 09:06:35 HD Request # 4 | Using server: ds7.sierracharts.com port 10149 | 2018-09-20 09:06:35 Socket (9) | Creating socket. | 2018-09-20 09:06:35 Socket (9) | Connecting to IP: 8.18.161.133. | 2018-09-20 09:06:35 Socket (9) | Signaling to core to close socket | 2018-09-20 09:06:55 Socket (9) | Closed. | 2018-09-20 09:06:55 HD Request # 4 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:06:55 Historical data download thread signaled to stop. | 2018-09-20 09:06:55 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:06:55 HD Request # 4 | Completion time: 20s | 2018-09-20 09:06:55 HD Request # 4 | Intraday data download complete for CLX18. Unique request ID: 1 | 2018-09-20 09:06:55 Removed historical data download ID 1 | 2018-09-20 09:06:55 Real-time Intraday chart data file updates started for CLX18 | 2018-09-20 09:06:55 Intraday chart data file opened for CLX18 | 2018-09-20 09:06:55 Intraday data recording state for symbol CLX18 is set to download 'Pending'. | 2018-09-20 09:09:52 Reloading all charts with filename: CLX18.scid | 2018-09-20 09:09:52 HD Request # 5 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:09:52 HD Request # 5 | Download start date-time: 2017-11-24 08:09:52.000 | 2018-09-20 09:09:52 HD Request # 5 | Using server: ds1.sierracharts.com port 10150 | 2018-09-20 09:09:52 Socket (13) | Creating socket. | 2018-09-20 09:09:52 Socket (13) | Connecting to IP: 8.18.161.135. | 2018-09-20 09:09:52 CLX18 1 Min #1 | Reloading chart. | 2018-09-20 09:09:53 CLX18 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLX18.scid | 2018-09-20 09:09:53 Socket (13) | Signaling to core to close socket | 2018-09-20 09:10:12 Socket (13) | Closed. | 2018-09-20 09:10:12 HD Request # 5 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:10:12 Historical data download thread signaled to stop. | 2018-09-20 09:10:12 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:10:12 HD Request # 5 | Completion time: 20s | 2018-09-20 09:10:12 HD Request # 6 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:10:12 HD Request # 6 | Download start date-time: 2017-11-24 08:10:12.000 | 2018-09-20 09:10:12 HD Request # 6 | Using server: ds7.sierracharts.com port 10149 | 2018-09-20 09:10:12 Socket (15) | Creating socket. | 2018-09-20 09:10:12 Socket (15) | Connecting to IP: 8.18.161.133. | 2018-09-20 09:10:12 Socket (15) | Signaling to core to close socket | 2018-09-20 09:10:32 Socket (15) | Closed. | 2018-09-20 09:10:32 HD Request # 6 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:10:32 Historical data download thread signaled to stop. | 2018-09-20 09:10:32 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:10:32 HD Request # 6 | Completion time: 20s | 2018-09-20 09:10:32 HD Request # 7 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:10:32 HD Request # 7 | Download start date-time: 2017-11-24 08:10:32.000 | 2018-09-20 09:10:32 HD Request # 7 | Using server: ds1.sierracharts.com port 10150 | 2018-09-20 09:10:32 Socket (16) | Creating socket. | 2018-09-20 09:10:32 Socket (16) | Connecting to IP: 8.18.161.135. | 2018-09-20 09:10:32 Socket (16) | Signaling to core to close socket | 2018-09-20 09:10:52 Socket (16) | Closed. | 2018-09-20 09:10:52 HD Request # 7 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:10:52 Historical data download thread signaled to stop. | 2018-09-20 09:10:52 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:10:52 HD Request # 7 | Completion time: 20s | 2018-09-20 09:10:52 HD Request # 7 | Intraday data download complete for CLX18. Unique request ID: 2 | 2018-09-20 09:10:52 Removed historical data download ID 2 | 2018-09-20 09:10:52 Real-time Intraday chart data file updates started for CLX18 | 2018-09-20 09:10:52 Intraday chart data file opened for CLX18 | 2018-09-20 09:10:52 File >> Disconnect selected. | 2018-09-20 09:11:53 SC Data - All Services | Disconnected. | 2018-09-20 09:11:53 SC Data - All Services | Connected to data server. | 2018-09-20 09:11:58 Mapping CLX18 to CLX18. Service code: nymex | 2018-09-20 09:11:59 SC Data - All Services | Starting real-time market data updates for: CLX18. ID: 1 | 2018-09-20 09:11:59 SC Data - All Services | Using username 0 | 2018-09-20 09:11:59 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-09-20 09:11:59 DTC Client socket (18) | Creating socket. | 2018-09-20 09:11:59 DTC Client socket (18) | Connecting to IP: 8.18.161.135. | 2018-09-20 09:11:59 SC Data - All Services | Requesting security definition data for: CLX18. ID: 1 | 2018-09-20 09:11:59 Intraday data recording state for symbol CLX18 is set to download 'Pending'. | 2018-09-20 09:11:59 Delaying start of download for CLX18 | 2018-09-20 09:11:59 SC Data - All Services | Connected to server. | 2018-09-20 09:11:59 SC Data - All Services | Starting socket receive thread. | 2018-09-20 09:11:59 SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-09-20 09:11:59 SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-09-20 09:11:59 SC Data - All Services | Sending logon request message. | 2018-09-20 09:11:59 SC Data - All Services | Received logon response. | 2018-09-20 09:11:59 SC Data - All Services | Server Name: SC Realtime Server. | 2018-09-20 09:11:59 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-09-20 09:11:59 SC Data - All Services | Successfully connected. | 2018-09-20 09:11:59 SC Data - All Services | Trading is not supported. | 2018-09-20 09:11:59 SC Data - All Services | Restarting real-time data updates for symbol: CLX18 -> CLX18 | 2018-09-20 09:11:59 SC Data - All Services | Received security definition for symbol CLX18 | 2018-09-20 09:11:59 HD Request # 8 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:12:04 HD Request # 8 | Download start date-time: 2017-11-24 08:12:03.000 | 2018-09-20 09:12:04 HD Request # 8 | Using server: ds7.sierracharts.com port 10149 | 2018-09-20 09:12:04 Socket (19) | Creating socket. | 2018-09-20 09:12:04 Socket (19) | Connecting to IP: 8.18.161.133. | 2018-09-20 09:12:04 Socket (19) | Signaling to core to close socket | 2018-09-20 09:12:24 Socket (19) | Closed. | 2018-09-20 09:12:24 HD Request # 8 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:12:24 Historical data download thread signaled to stop. | 2018-09-20 09:12:24 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:12:24 HD Request # 8 | Completion time: 20s | 2018-09-20 09:12:24 HD Request # 9 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:12:24 HD Request # 9 | Download start date-time: 2017-11-24 08:12:23.000 | 2018-09-20 09:12:24 HD Request # 9 | Using server: ds1.sierracharts.com port 10150 | 2018-09-20 09:12:24 Socket (21) | Creating socket. | 2018-09-20 09:12:24 Socket (21) | Connecting to IP: 8.18.161.135. | 2018-09-20 09:12:24 Socket (21) | Signaling to core to close socket | 2018-09-20 09:12:44 Socket (21) | Closed. | 2018-09-20 09:12:44 HD Request # 9 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:12:44 Historical data download thread signaled to stop. | 2018-09-20 09:12:44 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:12:44 HD Request # 9 | Completion time: 20s | 2018-09-20 09:12:44 HD Request # 10 | Downloading Intraday chart data for CLX18 to the file CLX18.scid. Service: nymex | 2018-09-20 09:12:44 HD Request # 10 | Download start date-time: 2017-11-24 08:12:43.000 | 2018-09-20 09:12:44 HD Request # 10 | Using server: ds7.sierracharts.com port 10149 | 2018-09-20 09:12:44 Socket (22) | Creating socket. | 2018-09-20 09:12:44 Socket (22) | Connecting to IP: 8.18.161.133. | 2018-09-20 09:12:44 Socket (22) | Signaling to core to close socket | 2018-09-20 09:13:04 Socket (22) | Closed. | 2018-09-20 09:13:04 HD Request # 10 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:13:04 Historical data download thread signaled to stop. | 2018-09-20 09:13:04 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLX18 | 2018-09-20 09:13:04 HD Request # 10 | Receiving Intraday data for CLX18 starting at 2018-09-20 09:12:21 | 2018-09-20 09:13:04 HD Request # 10 | Timestamp of first Intraday data file record written: 2018-09-20 09:12:21 | 2018-09-20 09:13:04 Added 665 Time and Sales records to Intraday data file for CLX18 after download. | 2018-09-20 09:13:04 HD Request # 10 | Completion time: 20s | 2018-09-20 09:13:04 HD Request # 10 | Intraday data download complete for CLX18. Unique request ID: 3 | 2018-09-20 09:13:04 Removed historical data download ID 3 | 2018-09-20 09:13:04 Real-time Intraday chart data file updates started for CLX18 | 2018-09-20 09:13:04 Intraday chart data file opened for CLX18 | 2018-09-20 09:13:04 Opened cached Intraday file: C:\SierraChart\Data\CLX18.scid | 2018-09-20 09:13:04 |
[2018-09-20 19:58:34] |
HD Request # 2 | Error downloading historical Intraday data for CLX18. Timeout error connecting to server. | 2018-09-20 09:06:15 Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
