Date/Time: Wed, 22 Jan 2025 06:52:06 +0000
Contracting price chart
View Count: 756
[2018-09-12 17:39:43]
nus1 - Posts: 39
How does one set chart to contract candles in accordance to time like its done on TradingView?
-please find screenshots attached-
imageTVvSC.png / V - Attached On 2018-09-12 17:33:32 UTC - Size: 48.69 KB - 296 views
[2018-09-13 04:42:16]
Refer to this section here:
Working With Charts: Changing Bar Spacing
Be sure to read through that entire section about bar spacing.
[2018-09-13 13:29:02]
nus1 - Posts: 39
What I managed to find in that section I am already using. None in there seems to tackle the problem showed above.
Problem is candle's decrease thickness limit & in result you are able to get twice less information on your screen.
Just to give you one example on why this is important
-lower time frame gives better representation of price structure break/bounce pressure relative to previous break/bounce pressures
-which is especially important in bigger range complex correction
[2018-09-13 16:53:34]
We cannot provide any further help with this. If Sierra Chart does not meet your requirements then use another program.
[2018-09-14 11:50:12]
nus1 - Posts: 39
Thank you for your thoughtful suggestion on my future trading en devours, however I'm not the one holding the support board.
Coming back to the relevant question, your answer is - no you can't see more price action on the screen than default and it's not priority for SC to make more price action visible on the chart.
Got you, thank you.
Date Time Of Last Edit: 2018-09-14 11:54:32
