Date/Time: Sun, 24 Nov 2024 09:23:52 +0000
Trade DOM Font
View Count: 1604
[2013-10-23 23:56:23]
Project88 - Posts: 3
I clicked on "Graphics" per the instructions on the DOM, adjusted all the settings. However, I could not find "File" to save. The trade setup configuration saved, but not the fonts, colors, etc. for the price, bid, ask, etc. I am only using the DOM - not the chart. How do I save these settings? Thank you.
[2013-10-24 00:01:55]
You need to save the Trade DOM window as part of the Chartbook. This is documented here:
http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html
[2013-10-24 00:24:10]
Thanks for the reply. I followed the instructions: opened my chartbook, opened the DOM, configured column graphics, opened a chart in the chartbook, saved as the chartbook name - still did not save when I closed and reopend the chartbook. Thanks.
[2013-10-24 01:46:56]
Must be doing something wrong. There should not be any trouble with this.
After you get everything set up as you need, go to File >> Close Chartbook. You will be prompted to save it. Choose Yes. Open the Chartbook. Everything should be restored as it was before.
