Date/Time: Wed, 22 Jan 2025 07:02:51 +0000
CHFSEK,CHFNOK, and other SEK/DKK/NOK intraday data only downloads up to 2015
View Count: 645
[2018-09-12 09:50:34]
User34124 - Posts: 279
I have gone through all the above. My settings are all correct because every other of my 100+ charts just loads as normal by default. My non-tick data is set to 3000, and even on my current chart, if I change to CHFxxx (dollar, yen etc), and press F5, it says date range 2010-06-13 to 2018-09-12 which is correct. Just changing symbol to CHFSEK or NOK makes it go to 2010-06-27 to 2015-01-30, which does not change at all no matter how many times I delete and redownload all data
[2018-09-12 15:45:23]
There is either no data available or no current data available for those pairs using the FXCM data feed.
But most likely you can get data but we are taking no responsibility for this data, by using the carrot character ^ in front of those symbols. Example: ^CHFSEK
Date Time Of Last Edit: 2018-09-12 15:45:51
