Date/Time: Wed, 22 Jan 2025 06:40:39 +0000
Announcement: CQG Users Do *Not* Need to Change Symbols
View Count: 1156
[2018-09-10 01:53:42] |
CQG has moved from single digit years to two digit years for their futures contract symbols over the weekend of 2018-09-10. Sierra Chart has always used two digit years for CQG futures symbols and always properly maps those to the security definition data received from the server. There is no need for you to make any changes . When using CQG with Sierra Chart, your charts, quote boards and Trading DOMs will update properly without any changes. There is simply nothing you need to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-10 01:59:38
