Date/Time: Wed, 22 Jan 2025 06:47:29 +0000
Bid/Ask Market Depth Pulling/Stacking Numbers import into Spreadsheet?
View Count: 2027
[2018-09-09 11:32:55] |
User618539 - Posts: 13 |
Hello, is there a way to reference the Bid/Ask Market Depth Pulling/Stacking Numbers in the DOM within a Spreadsheet or to import the data into a Spreadsheet? TIA Peter |
[2018-09-10 18:04:10] |
Yes this is now supported with the Depth of Market Data study: Depth of Market Data You will need to update to the current version of Sierra Chart for this: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-10 18:05:17
