Date/Time: Fri, 31 Jan 2025 12:49:04 +0000
Duplicate Bars on Daily Chart
View Count: 979
[2018-09-08 22:37:23]
jomanos - Posts: 27
I am having a similar issue as outlined in this 2014 post: Duplicated bar on historical charts
Using TD Ameritrade Data Feed for equities, on some symbols I get a duplicate bar on the daily chart (Friday's bar is replicated as a Saturday bar).
I have attached a screenshot showing the daily chart with the main chart settings and the global symbol settings for the historic chart. With the duplicate bars highlighted.
Since this involves the Last Trade Date-Time in the Market Data Snapshot server client communication, is there anything I can do to fix? (Understanding that the TD Ameritrade service is not maintained by SC.)
Thank you.
imageDouble Daily Bars_SQ_20180907.PNG / V - Attached On 2018-09-08 22:09:27 UTC - Size: 222.79 KB - 309 views
[2019-04-10 23:14:30]
abn2609 - Posts: 15
I am getting this bug too in more than one exchange. Can someone please look into this?
EOSUSD BITFINEX
http://www.sierrachart.com/image.php?Image=1554937960384.png
XBTUSD BMEX
http://www.sierrachart.com/image.php?Image=1554937940851.png
Private File
Private File
[2019-04-12 00:34:14]
In regards to post #1, we will look at that. This is inherently difficult to resolve.
In regards to post #2, this should be resolvable. What time zone do you have Sierra Chart set to? Refer to:
Time Zone Setting
Also check the time zone on the chart to see if you set a specific time zone there.
[2019-04-12 03:29:06]
In regards to post #1 we have implemented a solution to that. Will be out in the next release.
[2019-05-08 23:51:59]
abn2609 - Posts: 15
This issue is back again.
FYI, my timezone is Sydney (+10AEST/+11AEDT)
[2019-05-09 04:11:40]
Do not set the Historical Daily chart to that time zone. Set the chart to the UTC time zone:
Time Zone Setting: Using Different Time Zone in Individual Charts
