Date/Time: Wed, 22 Jan 2025 04:22:27 +0000
Something Very Simple
View Count: 584
[2018-09-08 20:36:46] |
User794190 - Posts: 26 |
I have a chartbook with several charts I use daily. I accidentally duplicated one of the charts -- which I want to delete. How do I delete a chart from a chartbook? I do not understand why this elementary action is so difficult. I checked the file and edit menus - in fact I checked all the menus and icons. No listing for delete. I also searched help "delete chart" in Help. Nothing. I looked at the Help Topic for Charting, looking for a listing on how to delete a chart. Nothing. |
[2018-09-08 21:16:48] |
The problem is that you you looking for the word "delete". The term would be "Remove". Refer to: Chartbooks (Workspaces): To Remove a Chart From a Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-08 21:17:08
