Date/Time: Wed, 22 Jan 2025 07:06:08 +0000
Can you help? I would to create a candle chart like the attached image?
View Count: 738
[2018-09-07 22:10:34] |
SierraFan - Posts: 92 |
Ive attached a image of a chart and I would like to create the same type of coloring style. You can see the color becomes a solid deep blue as it reaches the highs and then tapers down to white in the center and then tapers to deep red lows. What are these color changes based on volume,etc...?Can you help? https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=21802 Date Time Of Last Edit: 2018-09-08 20:08:44
Screenshot_1.png / V - Attached On 2018-09-07 22:04:50 UTC - Size: 221.34 KB - 293 views |
[2018-09-09 23:09:02] |
Sierra Chart does not have any built-in coloring method like this, but you can always create a custom study which can accomplish this.
[2018-09-10 01:12:57] |
User731023 - Posts: 138 |
If that is from @blb_capital it is based on other things. Ask him, he will tell you. |
