Date/Time: Wed, 22 Jan 2025 04:33:25 +0000
another rookie question
View Count: 645
[2018-09-07 16:54:01] |
User672082 - Posts: 62 |
what if there is a workbook that has charts w/no scroll or title bar, are maximized and I cannot make them small again or attach them to anything on main window to change the scale? The chart w/no title bar, etc, wont even give me room to shrink it or anything.
[2018-09-08 01:49:59] |
In this case what you need to do is add Chart Shortcut menu commands for the Title Bar and Scroll Bar and then you can right-click on that chart and enable those. Refer to: Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-08 01:50:26
[2018-09-08 12:19:35] |
thank you very much!
