Date/Time: Wed, 22 Jan 2025 04:12:29 +0000
breakeven
View Count: 1352
[2018-09-07 13:42:05]
Trader&Hunter - Posts: 131
is there a way I can set up the dom that if i ever hit the breakeven button it actually is break even plus 10?
[2018-09-07 15:19:49]
Xfanman1 - Posts: 320
You can set your offset in the Trade Window under the Set Tab. You can use a negative or positive amount and your Break Even button will move your attached Stop by that offset. BUT....at the moment (for me anyway) when using multiple entries the Break Even button is not averaging the orders accurately and the BE button is useless. For single entries, it works perfectly. Just FYI.
Scott
imageBreakEvenOffset.PNG / V - Attached On 2018-09-07 15:19:45 UTC - Size: 24.59 KB - 297 views
[2018-09-07 15:28:52]
yep it will be a single order. I will check it out. thanks
[2018-09-07 17:05:04]
Refer to this setting for the Trade Window:
Basic Trading and the Trade Window: Set >> Move to BE Offset
