Date/Time: Wed, 24 Apr 2024 22:28:36 +0000
[User Discussion] - Moving Average Type Selection
View Count: 969
[2018-09-07 11:05:52] |
User952186 - Posts: 58 |
I am using Jurik Tools with SC. Lots of studies include moving average selection I am wondering how I can select JMA (Jurik moving average) in this drop-down boxes. Thanks.
[2019-08-26 09:21:11] |
ILIM KIRGIZ - Posts: 187 |
I would also appreciate such a possibility. Thanks. Date Time Of Last Edit: 2019-08-26 09:21:41
[2019-08-26 18:30:42] |
You need to use this functionality instead to the extent it will be possible for what you want: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
