Date/Time: Wed, 22 Jan 2025 04:31:29 +0000
High/Low Time Period Chart
View Count: 2133
[2018-09-06 15:30:32] |
User750920 - Posts: 280 |
The High/Low time period (night session) study is not displaying on a RTH chart. I would like to display a Label and/or Line on a RTH chart of the Overnight (evening) session.
[2018-09-06 20:08:03] |
You must not be using the study correctly and what is the exact name of the study you are using?
[2018-09-06 21:04:17] |
The name of the study is High/Low for Time Period. The settings are set this way. Start Time - 14:00:00 End Time - 06:29:59 Input Data High - High Input Data Low - Low Display High Low Incrementally - No Number of Days to Calculate - 1 And the Chart Settings are set to the same time without Use Evening Session selected as I only want this on the RTH chart. Date Time Of Last Edit: 2018-09-06 21:09:45
[2018-09-06 23:11:18] |
Use High/Low For Time Period-Extended instead: High/Low for Time Period - Extended Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-07 03:51:01] |
It works only if I include the evening session (have the "Use evening Session" box checked) in the chart settings. I want to display the overnight (evening) High and Low without the box checked - the chart showing only RTH (day session only). Have the day session only with reference lines for the evening session high and low.
[2018-09-07 19:49:18] |
Therefore to accomplish this you need to follow the instructions here: https://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php#OverlayStudyDiffSessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
