Date/Time: Wed, 22 Jan 2025 07:08:43 +0000
Highlight Point Of Control needs attention.
View Count: 979
[2018-09-06 10:40:43]
User731023 - Posts: 138
When you choose "Extension Line Until Further Intersected"
in Highlight Point of Control, the line stops
when intersected but it still shows the number in Values scale
when it should no longer. (Because it was intersected.)
I am on version 1798 but it started on 1795.
Please see attached.
image1mmm.jpg / V - Attached On 2018-09-06 10:37:33 UTC - Size: 195.32 KB - 372 views
[2018-09-06 12:24:21]
apollofl - Posts: 95
Agree this need to be corrected.
[2018-09-06 16:17:58]
User657944 - Posts: 173
I confirm this was a feature that I ask for some months ago and now it works but has this issue that it's noisy and should be solved.thx
[2018-09-08 15:04:48]
As requested....Using Numberbars with Highlight Point Of Control with column 1 with extension line until future intersection. the POC's that were intersected are still showing on the Name and Value labels
http://www.sierrachart.com/image.php?Image=1536407445880.png
http://www.sierrachart.com/image.php?Image=1536408139492.png
[2018-09-09 01:28:35]
Okay we understand what you are asking about here. We can solve this.
[2018-09-10 01:33:11]
Fixed in pre-release.
image1mmm.jpg / V - Attached On 2018-09-10 01:33:06 UTC - Size: 168.61 KB - 290 views
[2018-09-10 01:44:12]
Which pre-release? Is there another pre-release besides 1800?
[2018-09-10 01:58:37]
No there is just 1800 and it does have the change that you have asked for. We did not change the version number yet because we are finishing with some other items related to logarithmic scaling.
Date Time Of Last Edit: 2018-09-10 01:58:52
[2018-09-10 02:08:53]
Ok, Great Job!
Date Time Of Last Edit: 2018-09-10 02:10:56
