Date/Time: Wed, 22 Jan 2025 04:38:54 +0000
Is there any place to store Constant Values in a Spreadsheet?
View Count: 650
[2018-09-06 10:01:30] |
User452567 - Posts: 38 |
Is there any place/cell to store Constant Values in a Spreadsheet so that when I copy&paste the spreadsheet to another folder, these Constant Values don't disappear? Thank you |
[2018-09-06 19:31:26] |
Yes, use any column which is not used by a formula which by default is K through Z, or any column AA or after which is not used by a study on the chart. We also do not understand the relevancy of copying a spreadsheet file. That does not change anything. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
