Date/Time: Wed, 22 Jan 2025 04:19:03 +0000
Control Bar end hidden
View Count: 611
[2018-09-06 06:32:35]
samual sprat - Posts: 343
If sierra chart application opens on my 1080p monitor and fits within the monitor boundaries and then I move the application to my 4k (or larger resolution monitor) full screen it, then the end of the control bar is cut off. I have quite a few items in my control bar of course, but all buttons fit on my 4k so this should not happen
Sunny
[2018-09-06 07:47:32]
We will look into this.
[2018-09-06 09:26:54]
Xfanman1 - Posts: 320
While the Engineering team looks at this, I have some experience with different resolution monitors. Is it possible you’re using text scaling on your 4K monitor that is enlarging the Control Bar Button Text and what fits at 100% on your 1920x1080 screen doesn’t fit on your 4K screen (let’s say scaled to 200%)? I’ve seen this with people using 5k Retina monitors and people using 4K laptop screens scaled to 300% just so the text can be read.
Just a thought .. Scott
[2018-09-07 08:39:33]
Hi Scott. Thanks for the reply. I have scaling set to 100% on all monitors as it windows handles scaling so badly and causes a lot of issues like you mention haha :)
