Date/Time: Sun, 24 Nov 2024 09:57:57 +0000
CTS Data Throughput and Buffering
View Count: 1314
[2013-10-23 16:51:10] |
natanibz - Posts: 134 |
Hello, with CTS where is possible to set the Data Throughput and Buffering ? Thanks Date Time Of Last Edit: 2013-10-23 16:51:46
[2013-10-23 17:42:06] |
Global Settings >> Data/Trade Service Settings. The setting is only in newer versions of Sierra Chart.
