Date/Time: Wed, 22 Jan 2025 04:12:10 +0000
I can not connect to your charts from my new laptop Lenovo
View Count: 640
[2018-09-06 01:29:55] |
User565382 - Posts: 6 |
HTTPS connection to www.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-09-05 17:58:00 HTTPS connection to www.sierrachart.com:443 (2) | Connecting to IP: 204.15.192.108. | 2018-09-05 17:58:00 Reading Internal Order ID file. | 2018-09-05 17:58:00 Reading Trade Orders file. | 2018-09-05 17:58:00 Reading Trade Positions and Account Balance file. | 2018-09-05 17:58:00 Listening on UDP port 22904. | 2018-09-05 17:58:00 Software version: 1781 32-bit | 2018-09-05 17:58:00 Usage end date: 2018-12-28 | 2018-09-05 17:58:00 Enabled for: Advanced Features. | 2018-09-05 17:58:00 Enabled for: Sierra Chart Historical Data Service. | 2018-09-05 17:58:00 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-09-05 17:58:00 Current selected Data/Trading service: TransAct Trading | 2018-09-05 17:58:00 Chart Update Interval: 500 | 2018-09-05 17:58:00 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-09-05 17:58:00 2018-09-05 17:58:00 Local computer time | 2018-09-05 17:58:00 2018-09-05 21:58:00 Local computer time in UTC | 2018-09-05 17:58:00 2018-09-05 17:58:00 Local computer time in SC Time Zone | 2018-09-05 17:58:00 2018-09-05 21:57:59 Server time in UTC | 2018-09-05 17:58:00 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-09-05 17:58:00 Program path: C:\SierraChart\ | 2018-09-05 17:58:00 Data Files path: C:\SierraChart\Data\ | 2018-09-05 17:58:00 OS Version Number: 10.0 | 2018-09-05 17:58:00 Locale Setting: C | 2018-09-05 17:58:00 Created the DTC Protocol server. | 2018-09-05 17:58:00 DTC Protocol Server listening on port 11099. | 2018-09-05 17:58:00 Created the DTC Protocol historical data server. | 2018-09-05 17:58:00 HD Server Manager | Listening on port 11098 | 2018-09-05 17:58:00 HD Server Manager | Listening on port 22903 | 2018-09-05 17:58:00 Checking for new symbol settings for service code transact.trading | 2018-09-05 17:58:00 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-09-05 17:58:00 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-09-05 17:58:00 Symbol settings are up-to-date for transact.trading | 2018-09-05 17:58:00 Received 5 login tokens. | 2018-09-05 17:58:01 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-09-05 17:58:02 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-09-05 17:58:02 Error getting list of user files to download. Response: ERROR: Downloading of files on startup is disabled | HTTP status: Request completed with the HTTP response status code 200. | 2018-09-05 17:58:02 HTTPS connection to login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-09-05 17:58:05 HTTPS connection to login.sierrachart.com:443 (1) | Received socket Close event. | 2018-09-05 17:58:05 HTTPS connection to login.sierrachart.com:443 (1) | Initiating close of socket by core. | 2018-09-05 17:58:05 HTTPS connection to login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 17:58:05 HTTPS connection to login.sierrachart.com:443 (1) | Closed. | 2018-09-05 17:58:05 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:58:05 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-09-05 17:58:05 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-09-05 17:58:05 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-09-05 17:58:05 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 17:58:05 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-09-05 17:58:05 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-09-05 17:58:06 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-09-05 17:58:06 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-09-05 17:58:06 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 17:58:06 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-09-05 17:58:06 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-09-05 17:58:07 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-09-05 17:58:07 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-09-05 17:58:07 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 17:58:07 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-09-05 17:58:07 TransAct Trading | Bridge process is not running! | 2018-09-05 17:58:07 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:58:07 DTC Client socket (6) | Creating socket. | 2018-09-05 17:58:07 DTC Client socket (6) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:58:07 DTC Client socket (6) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:58:08 * DTC Client socket (6) | Initiating close of socket by core. | 2018-09-05 17:58:08 DTC Client socket (6) | Closed. | 2018-09-05 17:58:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:58:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:08 TransAct Trading | Disconnected. | 2018-09-05 17:58:08 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:08 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:58:13 TransAct Trading | Bridge process is not running! | 2018-09-05 17:58:15 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:58:15 DTC Client socket (7) | Creating socket. | 2018-09-05 17:58:15 DTC Client socket (7) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:58:15 DTC Client socket (7) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:58:16 * DTC Client socket (7) | Initiating close of socket by core. | 2018-09-05 17:58:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:58:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:16 DTC Client socket (7) | Closed. | 2018-09-05 17:58:16 TransAct Trading | Disconnected. | 2018-09-05 17:58:17 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:17 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:58:22 TransAct Trading | Bridge process is not running! | 2018-09-05 17:58:24 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:58:24 DTC Client socket (8) | Creating socket. | 2018-09-05 17:58:24 DTC Client socket (8) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:58:24 DTC Client socket (8) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:58:25 * DTC Client socket (8) | Initiating close of socket by core. | 2018-09-05 17:58:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:58:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:25 DTC Client socket (8) | Closed. | 2018-09-05 17:58:25 TransAct Trading | Disconnected. | 2018-09-05 17:58:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:25 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:58:30 TransAct Trading | Bridge process is not running! | 2018-09-05 17:58:32 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:58:32 DTC Client socket (9) | Creating socket. | 2018-09-05 17:58:32 DTC Client socket (9) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:58:32 DTC Client socket (9) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:58:33 * DTC Client socket (9) | Initiating close of socket by core. | 2018-09-05 17:58:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:58:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:33 DTC Client socket (9) | Closed. | 2018-09-05 17:58:33 TransAct Trading | Disconnected. | 2018-09-05 17:58:33 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:33 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:58:38 TransAct Trading | Bridge process is not running! | 2018-09-05 17:58:40 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:58:40 DTC Client socket (10) | Creating socket. | 2018-09-05 17:58:40 DTC Client socket (10) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:58:40 DTC Client socket (10) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:58:41 * DTC Client socket (10) | Initiating close of socket by core. | 2018-09-05 17:58:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:58:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:41 DTC Client socket (10) | Closed. | 2018-09-05 17:58:41 TransAct Trading | Disconnected. | 2018-09-05 17:58:41 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:41 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:58:46 TransAct Trading | Bridge process is not running! | 2018-09-05 17:58:48 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:58:48 DTC Client socket (11) | Creating socket. | 2018-09-05 17:58:48 DTC Client socket (11) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:58:48 DTC Client socket (11) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:58:49 * DTC Client socket (11) | Initiating close of socket by core. | 2018-09-05 17:58:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:58:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:49 DTC Client socket (11) | Closed. | 2018-09-05 17:58:49 TransAct Trading | Disconnected. | 2018-09-05 17:58:49 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:49 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:58:54 TransAct Trading | Bridge process is not running! | 2018-09-05 17:58:56 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:58:56 DTC Client socket (12) | Creating socket. | 2018-09-05 17:58:56 DTC Client socket (12) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:58:56 DTC Client socket (12) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:58:57 * DTC Client socket (12) | Initiating close of socket by core. | 2018-09-05 17:58:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:58:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:57 DTC Client socket (12) | Closed. | 2018-09-05 17:58:57 TransAct Trading | Disconnected. | 2018-09-05 17:58:57 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:58:57 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:59:02 TransAct Trading | Bridge process is not running! | 2018-09-05 17:59:04 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:59:04 DTC Client socket (14) | Creating socket. | 2018-09-05 17:59:04 DTC Client socket (14) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:59:04 DTC Client socket (14) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:59:05 * DTC Client socket (14) | Initiating close of socket by core. | 2018-09-05 17:59:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:59:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:05 DTC Client socket (14) | Closed. | 2018-09-05 17:59:05 TransAct Trading | Disconnected. | 2018-09-05 17:59:05 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:05 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:59:10 TransAct Trading | Bridge process is not running! | 2018-09-05 17:59:12 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:59:12 DTC Client socket (15) | Creating socket. | 2018-09-05 17:59:12 DTC Client socket (15) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:59:12 DTC Client socket (15) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:59:13 * DTC Client socket (15) | Initiating close of socket by core. | 2018-09-05 17:59:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:59:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:13 DTC Client socket (15) | Closed. | 2018-09-05 17:59:13 TransAct Trading | Disconnected. | 2018-09-05 17:59:13 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:13 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:59:18 TransAct Trading | Bridge process is not running! | 2018-09-05 17:59:20 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:59:20 DTC Client socket (16) | Creating socket. | 2018-09-05 17:59:20 DTC Client socket (16) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:59:20 DTC Client socket (16) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:59:21 * DTC Client socket (16) | Initiating close of socket by core. | 2018-09-05 17:59:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:59:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:21 DTC Client socket (16) | Closed. | 2018-09-05 17:59:21 TransAct Trading | Disconnected. | 2018-09-05 17:59:21 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:21 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:59:26 TransAct Trading | Bridge process is not running! | 2018-09-05 17:59:28 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:59:28 DTC Client socket (17) | Creating socket. | 2018-09-05 17:59:28 DTC Client socket (17) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:59:28 DTC Client socket (17) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:59:29 * DTC Client socket (17) | Initiating close of socket by core. | 2018-09-05 17:59:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:59:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:29 DTC Client socket (17) | Closed. | 2018-09-05 17:59:29 TransAct Trading | Disconnected. | 2018-09-05 17:59:29 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:29 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:59:34 TransAct Trading | Bridge process is not running! | 2018-09-05 17:59:36 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:59:36 DTC Client socket (18) | Creating socket. | 2018-09-05 17:59:36 DTC Client socket (18) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:59:36 DTC Client socket (18) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:59:37 * DTC Client socket (18) | Initiating close of socket by core. | 2018-09-05 17:59:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:59:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:37 DTC Client socket (18) | Closed. | 2018-09-05 17:59:37 TransAct Trading | Disconnected. | 2018-09-05 17:59:37 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:37 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:59:42 TransAct Trading | Bridge process is not running! | 2018-09-05 17:59:44 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:59:44 DTC Client socket (19) | Creating socket. | 2018-09-05 17:59:44 DTC Client socket (19) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:59:44 DTC Client socket (19) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:59:45 * DTC Client socket (19) | Initiating close of socket by core. | 2018-09-05 17:59:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:59:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:45 DTC Client socket (19) | Closed. | 2018-09-05 17:59:45 TransAct Trading | Disconnected. | 2018-09-05 17:59:45 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:45 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:59:50 TransAct Trading | Bridge process is not running! | 2018-09-05 17:59:52 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 17:59:52 DTC Client socket (20) | Creating socket. | 2018-09-05 17:59:52 DTC Client socket (20) | Connecting to IP: 127.0.0.1. | 2018-09-05 17:59:52 DTC Client socket (20) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 17:59:53 * DTC Client socket (20) | Initiating close of socket by core. | 2018-09-05 17:59:53 DTC Client socket (20) | Closed. | 2018-09-05 17:59:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 17:59:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:53 TransAct Trading | Disconnected. | 2018-09-05 17:59:53 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 17:59:53 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 17:59:58 TransAct Trading | Bridge process is not running! | 2018-09-05 18:00:00 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:00:00 DTC Client socket (22) | Creating socket. | 2018-09-05 18:00:00 DTC Client socket (22) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:00:00 DTC Client socket (22) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:00:01 * DTC Client socket (22) | Initiating close of socket by core. | 2018-09-05 18:00:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:00:01 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:01 DTC Client socket (22) | Closed. | 2018-09-05 18:00:01 TransAct Trading | Disconnected. | 2018-09-05 18:00:01 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:01 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:00:06 TransAct Trading | Bridge process is not running! | 2018-09-05 18:00:08 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:00:08 DTC Client socket (23) | Creating socket. | 2018-09-05 18:00:08 DTC Client socket (23) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:00:08 DTC Client socket (23) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:00:09 * DTC Client socket (23) | Initiating close of socket by core. | 2018-09-05 18:00:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:00:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:09 DTC Client socket (23) | Closed. | 2018-09-05 18:00:09 TransAct Trading | Disconnected. | 2018-09-05 18:00:09 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:09 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:00:14 TransAct Trading | Bridge process is not running! | 2018-09-05 18:00:16 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:00:16 DTC Client socket (24) | Creating socket. | 2018-09-05 18:00:16 DTC Client socket (24) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:00:16 DTC Client socket (24) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:00:17 * DTC Client socket (24) | Initiating close of socket by core. | 2018-09-05 18:00:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:00:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:17 DTC Client socket (24) | Closed. | 2018-09-05 18:00:17 TransAct Trading | Disconnected. | 2018-09-05 18:00:17 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:17 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:00:22 TransAct Trading | Bridge process is not running! | 2018-09-05 18:00:24 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:00:24 DTC Client socket (25) | Creating socket. | 2018-09-05 18:00:24 DTC Client socket (25) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:00:24 DTC Client socket (25) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:00:25 * DTC Client socket (25) | Initiating close of socket by core. | 2018-09-05 18:00:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:00:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:25 DTC Client socket (25) | Closed. | 2018-09-05 18:00:25 TransAct Trading | Disconnected. | 2018-09-05 18:00:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:25 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:00:30 TransAct Trading | Bridge process is not running! | 2018-09-05 18:00:32 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:00:32 DTC Client socket (26) | Creating socket. | 2018-09-05 18:00:32 DTC Client socket (26) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:00:32 DTC Client socket (26) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:00:33 * DTC Client socket (26) | Initiating close of socket by core. | 2018-09-05 18:00:33 DTC Client socket (26) | Closed. | 2018-09-05 18:00:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:00:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:33 TransAct Trading | Disconnected. | 2018-09-05 18:00:33 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:33 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:00:38 TransAct Trading | Bridge process is not running! | 2018-09-05 18:00:40 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:00:40 DTC Client socket (27) | Creating socket. | 2018-09-05 18:00:40 DTC Client socket (27) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:00:40 DTC Client socket (27) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:00:41 * DTC Client socket (27) | Initiating close of socket by core. | 2018-09-05 18:00:41 DTC Client socket (27) | Closed. | 2018-09-05 18:00:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:00:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:41 TransAct Trading | Disconnected. | 2018-09-05 18:00:41 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:41 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:00:46 TransAct Trading | Bridge process is not running! | 2018-09-05 18:00:48 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:00:48 DTC Client socket (28) | Creating socket. | 2018-09-05 18:00:48 DTC Client socket (28) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:00:48 DTC Client socket (28) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:00:49 * DTC Client socket (28) | Initiating close of socket by core. | 2018-09-05 18:00:49 DTC Client socket (28) | Closed. | 2018-09-05 18:00:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:00:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:49 TransAct Trading | Disconnected. | 2018-09-05 18:00:49 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:49 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:00:54 TransAct Trading | Bridge process is not running! | 2018-09-05 18:00:56 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:00:56 DTC Client socket (29) | Creating socket. | 2018-09-05 18:00:56 DTC Client socket (29) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:00:56 DTC Client socket (29) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:00:57 * DTC Client socket (29) | Initiating close of socket by core. | 2018-09-05 18:00:57 DTC Client socket (29) | Closed. | 2018-09-05 18:00:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:00:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:57 TransAct Trading | Disconnected. | 2018-09-05 18:00:57 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:00:57 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:01:02 TransAct Trading | Bridge process is not running! | 2018-09-05 18:01:04 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:01:04 DTC Client socket (31) | Creating socket. | 2018-09-05 18:01:04 DTC Client socket (31) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:01:04 DTC Client socket (31) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:01:05 * DTC Client socket (31) | Initiating close of socket by core. | 2018-09-05 18:01:05 DTC Client socket (31) | Closed. | 2018-09-05 18:01:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:01:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:05 TransAct Trading | Disconnected. | 2018-09-05 18:01:05 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:05 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:01:10 TransAct Trading | Bridge process is not running! | 2018-09-05 18:01:12 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:01:12 DTC Client socket (32) | Creating socket. | 2018-09-05 18:01:12 DTC Client socket (32) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:01:12 DTC Client socket (32) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:01:13 * DTC Client socket (32) | Initiating close of socket by core. | 2018-09-05 18:01:13 DTC Client socket (32) | Closed. | 2018-09-05 18:01:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:01:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:13 TransAct Trading | Disconnected. | 2018-09-05 18:01:13 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:13 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:01:18 TransAct Trading | Bridge process is not running! | 2018-09-05 18:01:20 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:01:20 DTC Client socket (33) | Creating socket. | 2018-09-05 18:01:20 DTC Client socket (33) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:01:20 DTC Client socket (33) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:01:21 * DTC Client socket (33) | Initiating close of socket by core. | 2018-09-05 18:01:21 DTC Client socket (33) | Closed. | 2018-09-05 18:01:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:01:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:21 TransAct Trading | Disconnected. | 2018-09-05 18:01:21 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:21 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:01:26 TransAct Trading | Bridge process is not running! | 2018-09-05 18:01:28 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:01:28 DTC Client socket (34) | Creating socket. | 2018-09-05 18:01:28 DTC Client socket (34) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:01:28 DTC Client socket (34) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:01:29 * DTC Client socket (34) | Initiating close of socket by core. | 2018-09-05 18:01:29 DTC Client socket (34) | Closed. | 2018-09-05 18:01:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:01:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:29 TransAct Trading | Disconnected. | 2018-09-05 18:01:29 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:29 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:01:34 TransAct Trading | Bridge process is not running! | 2018-09-05 18:01:36 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:01:36 DTC Client socket (35) | Creating socket. | 2018-09-05 18:01:36 DTC Client socket (35) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:01:36 DTC Client socket (35) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:01:37 * DTC Client socket (35) | Initiating close of socket by core. | 2018-09-05 18:01:37 DTC Client socket (35) | Closed. | 2018-09-05 18:01:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:01:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:37 TransAct Trading | Disconnected. | 2018-09-05 18:01:37 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:37 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:01:42 TransAct Trading | Bridge process is not running! | 2018-09-05 18:01:44 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:01:44 DTC Client socket (36) | Creating socket. | 2018-09-05 18:01:44 DTC Client socket (36) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:01:44 DTC Client socket (36) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:01:45 * DTC Client socket (36) | Initiating close of socket by core. | 2018-09-05 18:01:45 DTC Client socket (36) | Closed. | 2018-09-05 18:01:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:01:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:45 TransAct Trading | Disconnected. | 2018-09-05 18:01:46 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:46 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:01:51 TransAct Trading | Bridge process is not running! | 2018-09-05 18:01:53 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:01:53 DTC Client socket (37) | Creating socket. | 2018-09-05 18:01:53 DTC Client socket (37) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:01:53 DTC Client socket (37) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:01:54 * DTC Client socket (37) | Initiating close of socket by core. | 2018-09-05 18:01:54 DTC Client socket (37) | Closed. | 2018-09-05 18:01:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:01:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:54 TransAct Trading | Disconnected. | 2018-09-05 18:01:54 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:01:54 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:01:59 TransAct Trading | Bridge process is not running! | 2018-09-05 18:02:01 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:02:01 DTC Client socket (39) | Creating socket. | 2018-09-05 18:02:01 DTC Client socket (39) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:02:01 DTC Client socket (39) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:02:02 * DTC Client socket (39) | Initiating close of socket by core. | 2018-09-05 18:02:02 DTC Client socket (39) | Closed. | 2018-09-05 18:02:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:02:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:02 TransAct Trading | Disconnected. | 2018-09-05 18:02:02 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:02 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:02:07 TransAct Trading | Bridge process is not running! | 2018-09-05 18:02:09 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:02:09 DTC Client socket (40) | Creating socket. | 2018-09-05 18:02:09 DTC Client socket (40) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:02:09 DTC Client socket (40) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:02:10 * DTC Client socket (40) | Initiating close of socket by core. | 2018-09-05 18:02:10 DTC Client socket (40) | Closed. | 2018-09-05 18:02:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:02:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:10 TransAct Trading | Disconnected. | 2018-09-05 18:02:10 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:10 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:02:15 TransAct Trading | Bridge process is not running! | 2018-09-05 18:02:17 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:02:17 DTC Client socket (41) | Creating socket. | 2018-09-05 18:02:17 DTC Client socket (41) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:02:17 DTC Client socket (41) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:02:18 * DTC Client socket (41) | Initiating close of socket by core. | 2018-09-05 18:02:18 DTC Client socket (41) | Closed. | 2018-09-05 18:02:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:02:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:18 TransAct Trading | Disconnected. | 2018-09-05 18:02:18 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:18 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:02:23 TransAct Trading | Bridge process is not running! | 2018-09-05 18:02:25 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:02:25 DTC Client socket (42) | Creating socket. | 2018-09-05 18:02:25 DTC Client socket (42) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:02:25 DTC Client socket (42) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:02:26 * DTC Client socket (42) | Initiating close of socket by core. | 2018-09-05 18:02:26 DTC Client socket (42) | Closed. | 2018-09-05 18:02:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:02:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:26 TransAct Trading | Disconnected. | 2018-09-05 18:02:26 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:26 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:02:31 TransAct Trading | Bridge process is not running! | 2018-09-05 18:02:33 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:02:33 DTC Client socket (43) | Creating socket. | 2018-09-05 18:02:33 DTC Client socket (43) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:02:33 DTC Client socket (43) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:02:34 * DTC Client socket (43) | Initiating close of socket by core. | 2018-09-05 18:02:34 DTC Client socket (43) | Closed. | 2018-09-05 18:02:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:02:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:34 TransAct Trading | Disconnected. | 2018-09-05 18:02:34 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:34 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:02:39 TransAct Trading | Bridge process is not running! | 2018-09-05 18:02:41 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:02:41 DTC Client socket (44) | Creating socket. | 2018-09-05 18:02:41 DTC Client socket (44) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:02:41 DTC Client socket (44) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:02:42 * DTC Client socket (44) | Initiating close of socket by core. | 2018-09-05 18:02:42 DTC Client socket (44) | Closed. | 2018-09-05 18:02:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:02:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:42 TransAct Trading | Disconnected. | 2018-09-05 18:02:42 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:42 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:02:47 TransAct Trading | Bridge process is not running! | 2018-09-05 18:02:49 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:02:49 DTC Client socket (45) | Creating socket. | 2018-09-05 18:02:49 DTC Client socket (45) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:02:49 DTC Client socket (45) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:02:50 * DTC Client socket (45) | Initiating close of socket by core. | 2018-09-05 18:02:50 DTC Client socket (45) | Closed. | 2018-09-05 18:02:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:02:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:50 TransAct Trading | Disconnected. | 2018-09-05 18:02:50 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:50 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:02:55 The message log has been sent to support. | 2018-09-05 18:02:57 HTTPS connection to www.sierrachart.com:443 (46) | Creating socket. Using TLS 1.2. | 2018-09-05 18:02:57 HTTPS connection to www.sierrachart.com:443 (46) | Connecting to IP: 204.15.192.108. | 2018-09-05 18:02:57 TransAct Trading | Bridge process is not running! | 2018-09-05 18:02:57 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:02:57 DTC Client socket (47) | Creating socket. | 2018-09-05 18:02:57 DTC Client socket (47) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:02:57 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2018-09-05 18:02:57 DTC Client socket (47) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:02:58 * DTC Client socket (47) | Initiating close of socket by core. | 2018-09-05 18:02:58 DTC Client socket (47) | Closed. | 2018-09-05 18:02:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:02:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:58 TransAct Trading | Disconnected. | 2018-09-05 18:02:58 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:02:58 HTTPS connection to www.sierrachart.com:443 (46) | Socket gracefully closed by remote side. | 2018-09-05 18:03:02 HTTPS connection to www.sierrachart.com:443 (46) | Received socket Close event. | 2018-09-05 18:03:02 HTTPS connection to www.sierrachart.com:443 (46) | Initiating close of socket by core. | 2018-09-05 18:03:02 HTTPS connection to www.sierrachart.com:443 (46) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 18:03:02 HTTPS connection to www.sierrachart.com:443 (46) | Closed. | 2018-09-05 18:03:02 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:03:03 TransAct Trading | Bridge process is not running! | 2018-09-05 18:03:05 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:03:05 DTC Client socket (49) | Creating socket. | 2018-09-05 18:03:05 DTC Client socket (49) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:03:05 DTC Client socket (49) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:03:06 * DTC Client socket (49) | Initiating close of socket by core. | 2018-09-05 18:03:06 DTC Client socket (49) | Closed. | 2018-09-05 18:03:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:03:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:06 TransAct Trading | Disconnected. | 2018-09-05 18:03:06 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:06 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:03:11 TransAct Trading | Bridge process is not running! | 2018-09-05 18:03:13 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:03:13 DTC Client socket (50) | Creating socket. | 2018-09-05 18:03:13 DTC Client socket (50) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:03:13 DTC Client socket (50) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:03:14 * DTC Client socket (50) | Initiating close of socket by core. | 2018-09-05 18:03:14 DTC Client socket (50) | Closed. | 2018-09-05 18:03:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:03:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:14 TransAct Trading | Disconnected. | 2018-09-05 18:03:14 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:14 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:03:19 TransAct Trading | Bridge process is not running! | 2018-09-05 18:03:21 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:03:21 DTC Client socket (51) | Creating socket. | 2018-09-05 18:03:21 DTC Client socket (51) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:03:21 DTC Client socket (51) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:03:22 * DTC Client socket (51) | Initiating close of socket by core. | 2018-09-05 18:03:22 DTC Client socket (51) | Closed. | 2018-09-05 18:03:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:03:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:22 TransAct Trading | Disconnected. | 2018-09-05 18:03:22 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:22 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:03:27 TransAct Trading | Bridge process is not running! | 2018-09-05 18:03:29 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:03:29 DTC Client socket (52) | Creating socket. | 2018-09-05 18:03:29 DTC Client socket (52) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:03:29 DTC Client socket (52) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:03:30 * DTC Client socket (52) | Initiating close of socket by core. | 2018-09-05 18:03:30 DTC Client socket (52) | Closed. | 2018-09-05 18:03:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:03:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:30 TransAct Trading | Disconnected. | 2018-09-05 18:03:30 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:30 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:03:35 TransAct Trading | Bridge process is not running! | 2018-09-05 18:03:37 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:03:37 DTC Client socket (53) | Creating socket. | 2018-09-05 18:03:37 DTC Client socket (53) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:03:37 DTC Client socket (53) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:03:38 * DTC Client socket (53) | Initiating close of socket by core. | 2018-09-05 18:03:38 DTC Client socket (53) | Closed. | 2018-09-05 18:03:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:03:38 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:38 TransAct Trading | Disconnected. | 2018-09-05 18:03:38 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:38 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:03:43 TransAct Trading | Bridge process is not running! | 2018-09-05 18:03:45 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:03:45 DTC Client socket (54) | Creating socket. | 2018-09-05 18:03:45 DTC Client socket (54) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:03:45 DTC Client socket (54) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:03:46 * DTC Client socket (54) | Initiating close of socket by core. | 2018-09-05 18:03:46 DTC Client socket (54) | Closed. | 2018-09-05 18:03:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:03:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:46 TransAct Trading | Disconnected. | 2018-09-05 18:03:46 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:46 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:03:51 TransAct Trading | Bridge process is not running! | 2018-09-05 18:03:53 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:03:53 DTC Client socket (55) | Creating socket. | 2018-09-05 18:03:53 DTC Client socket (55) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:03:53 DTC Client socket (55) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:03:54 * DTC Client socket (55) | Initiating close of socket by core. | 2018-09-05 18:03:54 DTC Client socket (55) | Closed. | 2018-09-05 18:03:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:03:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:54 TransAct Trading | Disconnected. | 2018-09-05 18:03:54 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:03:54 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:03:59 TransAct Trading | Bridge process is not running! | 2018-09-05 18:04:01 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:04:01 DTC Client socket (57) | Creating socket. | 2018-09-05 18:04:01 DTC Client socket (57) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:04:01 DTC Client socket (57) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:04:02 * DTC Client socket (57) | Initiating close of socket by core. | 2018-09-05 18:04:02 DTC Client socket (57) | Closed. | 2018-09-05 18:04:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:04:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:02 TransAct Trading | Disconnected. | 2018-09-05 18:04:02 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:02 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:04:07 TransAct Trading | Bridge process is not running! | 2018-09-05 18:04:09 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:04:09 DTC Client socket (58) | Creating socket. | 2018-09-05 18:04:09 DTC Client socket (58) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:04:09 DTC Client socket (58) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:04:10 * DTC Client socket (58) | Initiating close of socket by core. | 2018-09-05 18:04:10 DTC Client socket (58) | Closed. | 2018-09-05 18:04:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:04:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:10 TransAct Trading | Disconnected. | 2018-09-05 18:04:10 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:10 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:04:15 TransAct Trading | Bridge process is not running! | 2018-09-05 18:04:17 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:04:17 DTC Client socket (59) | Creating socket. | 2018-09-05 18:04:17 DTC Client socket (59) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:04:17 DTC Client socket (59) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:04:18 * DTC Client socket (59) | Initiating close of socket by core. | 2018-09-05 18:04:18 DTC Client socket (59) | Closed. | 2018-09-05 18:04:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:04:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:18 TransAct Trading | Disconnected. | 2018-09-05 18:04:18 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:18 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:04:23 TransAct Trading | Bridge process is not running! | 2018-09-05 18:04:25 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:04:25 DTC Client socket (60) | Creating socket. | 2018-09-05 18:04:25 DTC Client socket (60) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:04:25 DTC Client socket (60) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:04:26 * DTC Client socket (60) | Initiating close of socket by core. | 2018-09-05 18:04:26 DTC Client socket (60) | Closed. | 2018-09-05 18:04:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:04:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:26 TransAct Trading | Disconnected. | 2018-09-05 18:04:26 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:26 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:04:31 TransAct Trading | Bridge process is not running! | 2018-09-05 18:04:33 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:04:33 DTC Client socket (61) | Creating socket. | 2018-09-05 18:04:33 DTC Client socket (61) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:04:33 DTC Client socket (61) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:04:34 * DTC Client socket (61) | Initiating close of socket by core. | 2018-09-05 18:04:34 DTC Client socket (61) | Closed. | 2018-09-05 18:04:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:04:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:34 TransAct Trading | Disconnected. | 2018-09-05 18:04:34 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:34 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:04:39 TransAct Trading | Bridge process is not running! | 2018-09-05 18:04:41 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:04:41 DTC Client socket (62) | Creating socket. | 2018-09-05 18:04:41 DTC Client socket (62) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:04:41 DTC Client socket (62) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:04:42 * DTC Client socket (62) | Initiating close of socket by core. | 2018-09-05 18:04:42 DTC Client socket (62) | Closed. | 2018-09-05 18:04:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:04:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:42 TransAct Trading | Disconnected. | 2018-09-05 18:04:42 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:04:42 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:06:42 TransAct Trading | Bridge process is not running! | 2018-09-05 18:06:44 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:06:44 DTC Client socket (65) | Creating socket. | 2018-09-05 18:06:44 DTC Client socket (65) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:06:44 DTC Client socket (65) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:06:45 * DTC Client socket (65) | Initiating close of socket by core. | 2018-09-05 18:06:45 DTC Client socket (65) | Closed. | 2018-09-05 18:06:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:06:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:06:45 TransAct Trading | Disconnected. | 2018-09-05 18:06:45 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:06:45 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:08:45 TransAct Trading | Bridge process is not running! | 2018-09-05 18:08:47 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:08:47 DTC Client socket (68) | Creating socket. | 2018-09-05 18:08:47 DTC Client socket (68) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:08:47 DTC Client socket (68) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:08:48 * DTC Client socket (68) | Initiating close of socket by core. | 2018-09-05 18:08:48 DTC Client socket (68) | Closed. | 2018-09-05 18:08:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:08:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:08:48 TransAct Trading | Disconnected. | 2018-09-05 18:08:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:08:48 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:10:48 TransAct Trading | Bridge process is not running! | 2018-09-05 18:10:50 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:10:50 DTC Client socket (71) | Creating socket. | 2018-09-05 18:10:50 DTC Client socket (71) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:10:50 DTC Client socket (71) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:10:51 * DTC Client socket (71) | Initiating close of socket by core. | 2018-09-05 18:10:51 DTC Client socket (71) | Closed. | 2018-09-05 18:10:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:10:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:10:51 TransAct Trading | Disconnected. | 2018-09-05 18:10:51 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:10:51 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:12:51 TransAct Trading | Bridge process is not running! | 2018-09-05 18:12:53 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:12:53 DTC Client socket (74) | Creating socket. | 2018-09-05 18:12:53 DTC Client socket (74) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:12:53 DTC Client socket (74) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:12:54 * DTC Client socket (74) | Initiating close of socket by core. | 2018-09-05 18:12:54 DTC Client socket (74) | Closed. | 2018-09-05 18:12:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:12:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:12:54 TransAct Trading | Disconnected. | 2018-09-05 18:12:54 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:12:54 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:14:54 TransAct Trading | Bridge process is not running! | 2018-09-05 18:14:56 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:14:56 DTC Client socket (77) | Creating socket. | 2018-09-05 18:14:56 DTC Client socket (77) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:14:56 DTC Client socket (77) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:14:57 * DTC Client socket (77) | Initiating close of socket by core. | 2018-09-05 18:14:57 DTC Client socket (77) | Closed. | 2018-09-05 18:14:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:14:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:14:57 TransAct Trading | Disconnected. | 2018-09-05 18:14:57 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:14:57 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:16:57 TransAct Trading | Bridge process is not running! | 2018-09-05 18:16:59 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:16:59 DTC Client socket (80) | Creating socket. | 2018-09-05 18:16:59 DTC Client socket (80) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:16:59 DTC Client socket (80) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:17:00 * DTC Client socket (80) | Initiating close of socket by core. | 2018-09-05 18:17:00 DTC Client socket (80) | Closed. | 2018-09-05 18:17:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:17:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:17:00 TransAct Trading | Disconnected. | 2018-09-05 18:17:00 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:17:00 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:19:00 TransAct Trading | Bridge process is not running! | 2018-09-05 18:19:02 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:19:02 DTC Client socket (84) | Creating socket. | 2018-09-05 18:19:02 DTC Client socket (84) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:19:02 DTC Client socket (84) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:19:03 * DTC Client socket (84) | Initiating close of socket by core. | 2018-09-05 18:19:03 DTC Client socket (84) | Closed. | 2018-09-05 18:19:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:19:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:19:03 TransAct Trading | Disconnected. | 2018-09-05 18:19:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:19:04 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:21:04 TransAct Trading | Bridge process is not running! | 2018-09-05 18:21:06 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:21:06 DTC Client socket (87) | Creating socket. | 2018-09-05 18:21:06 DTC Client socket (87) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:21:06 DTC Client socket (87) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:21:07 * DTC Client socket (87) | Initiating close of socket by core. | 2018-09-05 18:21:07 DTC Client socket (87) | Closed. | 2018-09-05 18:21:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:21:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:21:07 TransAct Trading | Disconnected. | 2018-09-05 18:21:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:21:07 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:23:07 TransAct Trading | Bridge process is not running! | 2018-09-05 18:23:09 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:23:09 DTC Client socket (90) | Creating socket. | 2018-09-05 18:23:09 DTC Client socket (90) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:23:09 DTC Client socket (90) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:23:10 * DTC Client socket (90) | Initiating close of socket by core. | 2018-09-05 18:23:10 DTC Client socket (90) | Closed. | 2018-09-05 18:23:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:23:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:23:10 TransAct Trading | Disconnected. | 2018-09-05 18:23:10 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:23:10 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:25:10 TransAct Trading | Bridge process is not running! | 2018-09-05 18:25:12 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:25:12 DTC Client socket (93) | Creating socket. | 2018-09-05 18:25:12 DTC Client socket (93) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:25:12 DTC Client socket (93) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:25:13 * DTC Client socket (93) | Initiating close of socket by core. | 2018-09-05 18:25:13 DTC Client socket (93) | Closed. | 2018-09-05 18:25:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:25:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:25:13 TransAct Trading | Disconnected. | 2018-09-05 18:25:13 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:25:13 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:27:13 TransAct Trading | Bridge process is not running! | 2018-09-05 18:27:15 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:27:15 DTC Client socket (96) | Creating socket. | 2018-09-05 18:27:15 DTC Client socket (96) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:27:15 DTC Client socket (96) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:27:16 * DTC Client socket (96) | Initiating close of socket by core. | 2018-09-05 18:27:16 DTC Client socket (96) | Closed. | 2018-09-05 18:27:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:27:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:27:16 TransAct Trading | Disconnected. | 2018-09-05 18:27:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:27:16 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:29:16 TransAct Trading | Bridge process is not running! | 2018-09-05 18:29:18 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:29:18 DTC Client socket (99) | Creating socket. | 2018-09-05 18:29:18 DTC Client socket (99) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:29:18 DTC Client socket (99) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:29:19 * DTC Client socket (99) | Initiating close of socket by core. | 2018-09-05 18:29:19 DTC Client socket (99) | Closed. | 2018-09-05 18:29:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:29:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:29:19 TransAct Trading | Disconnected. | 2018-09-05 18:29:19 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:29:19 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:31:19 TransAct Trading | Bridge process is not running! | 2018-09-05 18:31:21 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:31:21 DTC Client socket (102) | Creating socket. | 2018-09-05 18:31:21 DTC Client socket (102) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:31:21 DTC Client socket (102) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:31:22 * DTC Client socket (102) | Initiating close of socket by core. | 2018-09-05 18:31:22 DTC Client socket (102) | Closed. | 2018-09-05 18:31:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:31:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:31:22 TransAct Trading | Disconnected. | 2018-09-05 18:31:22 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:31:22 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:33:22 TransAct Trading | Bridge process is not running! | 2018-09-05 18:33:24 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:33:24 DTC Client socket (105) | Creating socket. | 2018-09-05 18:33:24 DTC Client socket (105) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:33:24 DTC Client socket (105) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:33:25 * DTC Client socket (105) | Initiating close of socket by core. | 2018-09-05 18:33:25 DTC Client socket (105) | Closed. | 2018-09-05 18:33:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:33:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:33:25 TransAct Trading | Disconnected. | 2018-09-05 18:33:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:33:25 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:35:25 TransAct Trading | Bridge process is not running! | 2018-09-05 18:35:27 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:35:27 DTC Client socket (108) | Creating socket. | 2018-09-05 18:35:27 DTC Client socket (108) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:35:27 DTC Client socket (108) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:35:28 * DTC Client socket (108) | Initiating close of socket by core. | 2018-09-05 18:35:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:35:28 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:35:28 DTC Client socket (108) | Closed. | 2018-09-05 18:35:28 TransAct Trading | Disconnected. | 2018-09-05 18:35:28 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:35:28 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:37:28 TransAct Trading | Bridge process is not running! | 2018-09-05 18:37:30 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:37:30 DTC Client socket (111) | Creating socket. | 2018-09-05 18:37:30 DTC Client socket (111) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:37:30 DTC Client socket (111) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:37:31 * DTC Client socket (111) | Initiating close of socket by core. | 2018-09-05 18:37:31 DTC Client socket (111) | Closed. | 2018-09-05 18:37:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:37:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:37:31 TransAct Trading | Disconnected. | 2018-09-05 18:37:31 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:37:31 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:39:31 TransAct Trading | Bridge process is not running! | 2018-09-05 18:39:33 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:39:33 DTC Client socket (114) | Creating socket. | 2018-09-05 18:39:33 DTC Client socket (114) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:39:33 DTC Client socket (114) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:39:34 * DTC Client socket (114) | Initiating close of socket by core. | 2018-09-05 18:39:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:39:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:39:34 DTC Client socket (114) | Closed. | 2018-09-05 18:39:34 TransAct Trading | Disconnected. | 2018-09-05 18:39:34 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:39:34 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:41:34 TransAct Trading | Bridge process is not running! | 2018-09-05 18:41:36 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:41:36 DTC Client socket (117) | Creating socket. | 2018-09-05 18:41:36 DTC Client socket (117) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:41:36 DTC Client socket (117) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:41:37 * DTC Client socket (117) | Initiating close of socket by core. | 2018-09-05 18:41:37 DTC Client socket (117) | Closed. | 2018-09-05 18:41:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:41:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:41:37 TransAct Trading | Disconnected. | 2018-09-05 18:41:37 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:41:37 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:43:37 TransAct Trading | Bridge process is not running! | 2018-09-05 18:43:39 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:43:39 DTC Client socket (120) | Creating socket. | 2018-09-05 18:43:39 DTC Client socket (120) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:43:39 DTC Client socket (120) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:43:40 * DTC Client socket (120) | Initiating close of socket by core. | 2018-09-05 18:43:40 DTC Client socket (120) | Closed. | 2018-09-05 18:43:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:43:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:43:40 TransAct Trading | Disconnected. | 2018-09-05 18:43:40 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:43:40 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:45:40 TransAct Trading | Bridge process is not running! | 2018-09-05 18:45:42 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:45:42 DTC Client socket (123) | Creating socket. | 2018-09-05 18:45:42 DTC Client socket (123) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:45:42 DTC Client socket (123) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:45:43 * DTC Client socket (123) | Initiating close of socket by core. | 2018-09-05 18:45:43 DTC Client socket (123) | Closed. | 2018-09-05 18:45:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:45:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:45:43 TransAct Trading | Disconnected. | 2018-09-05 18:45:43 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:45:43 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:47:43 TransAct Trading | Bridge process is not running! | 2018-09-05 18:47:45 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:47:45 DTC Client socket (126) | Creating socket. | 2018-09-05 18:47:45 DTC Client socket (126) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:47:45 DTC Client socket (126) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:47:46 * DTC Client socket (126) | Initiating close of socket by core. | 2018-09-05 18:47:46 DTC Client socket (126) | Closed. | 2018-09-05 18:47:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:47:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:47:46 TransAct Trading | Disconnected. | 2018-09-05 18:47:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:47:46 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:49:46 TransAct Trading | Bridge process is not running! | 2018-09-05 18:49:48 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:49:48 DTC Client socket (129) | Creating socket. | 2018-09-05 18:49:48 DTC Client socket (129) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:49:48 DTC Client socket (129) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:49:49 * DTC Client socket (129) | Initiating close of socket by core. | 2018-09-05 18:49:49 DTC Client socket (129) | Closed. | 2018-09-05 18:49:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:49:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:49:49 TransAct Trading | Disconnected. | 2018-09-05 18:49:49 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:49:49 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:51:49 TransAct Trading | Bridge process is not running! | 2018-09-05 18:51:51 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:51:51 DTC Client socket (132) | Creating socket. | 2018-09-05 18:51:51 DTC Client socket (132) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:51:51 DTC Client socket (132) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:51:52 * DTC Client socket (132) | Initiating close of socket by core. | 2018-09-05 18:51:52 DTC Client socket (132) | Closed. | 2018-09-05 18:51:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:51:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:51:52 TransAct Trading | Disconnected. | 2018-09-05 18:51:52 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:51:52 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:53:52 TransAct Trading | Bridge process is not running! | 2018-09-05 18:53:54 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:53:54 DTC Client socket (135) | Creating socket. | 2018-09-05 18:53:54 DTC Client socket (135) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:53:54 DTC Client socket (135) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:53:55 * DTC Client socket (135) | Initiating close of socket by core. | 2018-09-05 18:53:55 DTC Client socket (135) | Closed. | 2018-09-05 18:53:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:53:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:53:55 TransAct Trading | Disconnected. | 2018-09-05 18:53:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:53:55 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:55:55 TransAct Trading | Bridge process is not running! | 2018-09-05 18:55:57 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:55:57 DTC Client socket (138) | Creating socket. | 2018-09-05 18:55:57 DTC Client socket (138) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:55:57 DTC Client socket (138) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:55:58 * DTC Client socket (138) | Initiating close of socket by core. | 2018-09-05 18:55:58 DTC Client socket (138) | Closed. | 2018-09-05 18:55:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:55:58 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:55:58 TransAct Trading | Disconnected. | 2018-09-05 18:55:58 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:55:58 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 18:57:58 TransAct Trading | Bridge process is not running! | 2018-09-05 18:58:00 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 18:58:00 DTC Client socket (142) | Creating socket. | 2018-09-05 18:58:00 DTC Client socket (142) | Connecting to IP: 127.0.0.1. | 2018-09-05 18:58:00 DTC Client socket (142) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 18:58:01 * DTC Client socket (142) | Initiating close of socket by core. | 2018-09-05 18:58:01 DTC Client socket (142) | Closed. | 2018-09-05 18:58:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 18:58:01 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:58:01 TransAct Trading | Disconnected. | 2018-09-05 18:58:01 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 18:58:01 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 19:00:01 TransAct Trading | Bridge process is not running! | 2018-09-05 19:00:03 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 19:00:03 DTC Client socket (145) | Creating socket. | 2018-09-05 19:00:03 DTC Client socket (145) | Connecting to IP: 127.0.0.1. | 2018-09-05 19:00:03 DTC Client socket (145) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 19:00:04 * DTC Client socket (145) | Initiating close of socket by core. | 2018-09-05 19:00:04 DTC Client socket (145) | Closed. | 2018-09-05 19:00:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 19:00:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:00:04 TransAct Trading | Disconnected. | 2018-09-05 19:00:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:00:04 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 19:02:04 TransAct Trading | Bridge process is not running! | 2018-09-05 19:02:06 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 19:02:06 DTC Client socket (148) | Creating socket. | 2018-09-05 19:02:06 DTC Client socket (148) | Connecting to IP: 127.0.0.1. | 2018-09-05 19:02:06 DTC Client socket (148) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 19:02:07 * DTC Client socket (148) | Initiating close of socket by core. | 2018-09-05 19:02:07 DTC Client socket (148) | Closed. | 2018-09-05 19:02:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 19:02:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:02:07 TransAct Trading | Disconnected. | 2018-09-05 19:02:07 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:02:07 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 19:04:07 TransAct Trading | Bridge process is not running! | 2018-09-05 19:04:09 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 19:04:09 DTC Client socket (151) | Creating socket. | 2018-09-05 19:04:09 DTC Client socket (151) | Connecting to IP: 127.0.0.1. | 2018-09-05 19:04:09 DTC Client socket (151) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 19:04:10 * DTC Client socket (151) | Initiating close of socket by core. | 2018-09-05 19:04:10 DTC Client socket (151) | Closed. | 2018-09-05 19:04:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 19:04:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:04:10 TransAct Trading | Disconnected. | 2018-09-05 19:04:10 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:04:10 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 19:06:10 TransAct Trading | Bridge process is not running! | 2018-09-05 19:06:12 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 19:06:12 DTC Client socket (154) | Creating socket. | 2018-09-05 19:06:12 DTC Client socket (154) | Connecting to IP: 127.0.0.1. | 2018-09-05 19:06:12 DTC Client socket (154) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 19:06:13 * DTC Client socket (154) | Initiating close of socket by core. | 2018-09-05 19:06:13 DTC Client socket (154) | Closed. | 2018-09-05 19:06:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 19:06:13 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:06:13 TransAct Trading | Disconnected. | 2018-09-05 19:06:13 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:06:13 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 19:08:13 TransAct Trading | Bridge process is not running! | 2018-09-05 19:08:15 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 19:08:15 DTC Client socket (157) | Creating socket. | 2018-09-05 19:08:15 DTC Client socket (157) | Connecting to IP: 127.0.0.1. | 2018-09-05 19:08:15 DTC Client socket (157) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 19:08:16 * DTC Client socket (157) | Initiating close of socket by core. | 2018-09-05 19:08:16 DTC Client socket (157) | Closed. | 2018-09-05 19:08:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 19:08:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:08:16 TransAct Trading | Disconnected. | 2018-09-05 19:08:16 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:08:16 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 19:10:16 TransAct Trading | Bridge process is not running! | 2018-09-05 19:10:18 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 19:10:18 DTC Client socket (160) | Creating socket. | 2018-09-05 19:10:18 DTC Client socket (160) | Connecting to IP: 127.0.0.1. | 2018-09-05 19:10:18 DTC Client socket (160) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 19:10:19 * DTC Client socket (160) | Initiating close of socket by core. | 2018-09-05 19:10:19 DTC Client socket (160) | Closed. | 2018-09-05 19:10:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 19:10:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:10:19 TransAct Trading | Disconnected. | 2018-09-05 19:10:19 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:10:19 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 19:12:19 TransAct Trading | Bridge process is not running! | 2018-09-05 19:12:21 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 19:12:21 DTC Client socket (163) | Creating socket. | 2018-09-05 19:12:21 DTC Client socket (163) | Connecting to IP: 127.0.0.1. | 2018-09-05 19:12:21 DTC Client socket (163) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 19:12:22 * DTC Client socket (163) | Initiating close of socket by core. | 2018-09-05 19:12:22 DTC Client socket (163) | Closed. | 2018-09-05 19:12:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 19:12:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:12:22 TransAct Trading | Disconnected. | 2018-09-05 19:12:22 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:12:22 TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2018-09-05 19:14:22 TransAct Trading | Bridge process is not running! | 2018-09-05 19:14:24 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2018-09-05 19:14:24 DTC Client socket (166) | Creating socket. | 2018-09-05 19:14:24 DTC Client socket (166) | Connecting to IP: 127.0.0.1. | 2018-09-05 19:14:24 DTC Client socket (166) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-09-05 19:14:25 * DTC Client socket (166) | Initiating close of socket by core. | 2018-09-05 19:14:25 DTC Client socket (166) | Closed. | 2018-09-05 19:14:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 19:14:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:14:25 TransAct Trading | Disconnected. | 2018-09-05 19:14:25 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 19:14:25 |
[2018-09-06 23:01:09] |
This is the relevant message: TransAct Trading | Bridge process is not running! | 2018-09-05 17:58:07 So for whatever unknown reason, after Sierra Chart is starting the bridge program, it is no longer running. You are going to need to contact Transact support for help with this. Have your broker put you in contact with them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-06 23:01:55
