Date/Time: Wed, 22 Jan 2025 04:34:07 +0000
Automated Log Analysis
View Count: 1128
[2018-09-05 17:02:39]
User750920 - Posts: 280
I just got a pop-up in my browser that showed my message log and that this was an automated response. It said my computers date and/or time are not set accurately.
I am confused because the data and time are the same for my computer and Sierra. The date is the same, The time may be off by seconds (is that an issue) since the tome does not sync everyday. The timezone is set on my computer at PST and Sierra is set to Los Angeles (PST). The only thing I see it that the compute says UTC-8:00 Pacific Time and Sierra says Los Angeles (-9PST/-7PDT)
I assume that is semantics and they represent the same thing.
[2018-09-05 18:11:59]
The time zone settings are not an issue.
The issue is that the computer's clock is off by 33 seconds.
For help refer to help topic 38 here:
http://www.sierrachart.com/index.php?page=doc/helpdetails38.html
[2018-09-05 19:12:11]
What is the best way to maintain the computer clock stays up to day without having to repeatedly update it via the update now in Internet time settings.
I have noticed it seems to change over a few days and my computer is always running.
[2018-09-05 20:44:48]
Xfanman1 - Posts: 320
I use an application called Dimension 4 that, once set up, is basically invisible and just syncs my PC's at whatever schedule I've set. There are a number of others that do the same thing but this one works great for me (and it's free).
http://www.thinkman.com/dimension4/
Scott
[2018-09-06 23:02:53]
Use this option:
General Settings Window: Periodically Set System Date-Time from Server (Global Settings >> General Settings >> General >> Update Intervals)
