Date/Time: Wed, 22 Jan 2025 04:12:04 +0000
Remove the name of the attached chart
View Count: 591
[2018-09-05 16:55:33]
User97684 - Posts: 136
Is it possible to remove / relocate the name of the attached chart together with the tool bar, in order to get more chart space down there.
Many thanks
imageremove_the_attached_chart_name.png / V - Attached On 2018-09-05 16:54:59 UTC - Size: 26.31 KB - 215 views
[2018-09-05 17:26:05]
Sierra Chart - Max - Posts: 5779
Yes, you can hide this by disabling the Show MDI Window Tabs option on Global Settings >> General Settings >> General 1 >> Tabs:
https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#WindowAndChartbookTabs
Sierra Chart Support
Date Time Of Last Edit: 2018-09-05 17:26:56
