Date/Time: Wed, 22 Jan 2025 04:32:16 +0000
Instance name ?
View Count: 704
[2018-09-05 13:08:08]
wwwingman - Posts: 185
Hi
I use multiple instances and end up losing time in the identification of the right instance because they are very similar. Is there is way to change the name of the instance, or add some info in the title of the main sierra window for a simpler identification ?
Thx.
-- W.
[2018-09-05 16:37:31]
Sierra Chart - Max - Posts: 5779
Yes, you can set a Custom Title Bar Name for each instance:
General Settings Window: Custom Title Bar Name (Global Settings >> General Settings >> GUI >> Application GUI)
Sierra Chart Support
