Date/Time: Wed, 22 Jan 2025 23:56:49 +0000
Confused with Market Depth Settings
View Count: 1423
[2018-09-05 12:36:43]
Cavalry3162 - Posts: 523
Hello SC,
i am a bit confused with the market depth levels settings..
what i want to do is to have on 3 of my 4 domss a number of market depth levels of 15 and on another (chart) dom with a market depth historical graph i want like 50 levels..
though i seem unable to achieve that.. there seems to be 3 settings available but only one setting actually changes soemthing in the number of levels displayed but that setting seems to only work globally..
there's the data/trade service settings, the chart settings and the chart dom settings..
no matter what i have in the trade service or chart settings its only the chart dom settings which change anything..
please advise.
imageData-Trade_Service_Settings.png / V - Attached On 2018-09-05 12:36:27 UTC - Size: 35.54 KB - 353 views
imageChart_Settings.png / V - Attached On 2018-09-05 12:36:32 UTC - Size: 47.86 KB - 311 views
imageChart_DOM_Settings.png / V - Attached On 2018-09-05 12:36:36 UTC - Size: 41.57 KB - 346 views
[2018-09-05 22:33:22]
We need to organize this better. Just give us a few days. We need to add a chart specific setting.
[2018-11-01 19:03:47]
have you done the reorganization?
for what i can tell there is no new behavior just one setting gone.. i can still set the depth levels in data settings and chart settings though none of them changes the number of levels anymore...
so, the only setting which was working was removed...(?)
thanks,
Andreas
[2018-11-01 19:48:48]
This new chart setting definitely controls the market depth levels throughout the chart object:
http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#MaximumMarketDepthLevels
There is no problem with it. It works very straightforward and reliably. This has been verified.
[2018-11-01 19:55:49]
aaah.. thank you.. and whats the Chart Settings -> Main Settings -> Market Depth for?
or do you remove it eventually?
Date Time Of Last Edit: 2018-11-01 19:56:11
