Date/Time: Wed, 22 Jan 2025 04:39:41 +0000
Depth Levels Available / EPU18
View Count: 671
[2018-09-05 06:31:11]
User371906 - Posts: 141
On my DOM Depth levels I can only see 5 levels, can you please tell me what settings to adjust to be able to see more.
Chart DOM Settings - Global / Max Bid/Ask Depth Pulling/Stacking Levels (0=All) I have selected 0
I have CQG as data feed and symbol is F.US.EPU18. (Version 1791)
http://www.sierrachart.com/image.php?Image=1536129010281.png
Thank you
Regards
Date Time Of Last Edit: 2018-09-05 07:08:21
[2018-09-05 08:12:41]
We think there probably are 10 levels but the scale is not correct. First make sure the Tick Size in Chart >> Chart Settings is set to .25 and then follow the instructions here to auto scale the Chart DOM:
The Chart DOM Scale: Auto Scale the Chart DOM
