Date/Time: Wed, 22 Jan 2025 04:22:08 +0000
Bug in 1795 - Draw Volume Profile - "Draw Profile Outline Enclosing Bars"
View Count: 1229
[2018-09-05 04:06:15] |
goodthinkin - Posts: 6 |
Seems the function listed above is no longer functioning in 1795. Amiright? Used to work. I updated 2 machines. No longer drawing the outline. Checked my settings. Could be user error but I can't find anything I am doing wrong. Thanks. Great product BTW guys. Keep up the good work! |
[2018-09-05 05:01:15] |
We are not seeing a problem with this in 1798. First try 1798 and if there is an issue we will need to get your Chartbook to test this.
[2018-09-05 15:22:14] |
Downloaded 1798. Still no luck getting the "Draw Profile Outline Enclosing Bars" (ln:63) to work for me. Was reading how to send a chartbook. Any special instructions? What email should I use? Thanks. |
[2018-09-05 18:09:14] |
Follow the instructions here to attach the particular chart containing the Volume by Price study: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-06 18:05:24] |
Here ya go. I hope it's not a user error. I hate to waste people's time with my mistakes. Sincere thanks. |
Support_01.Cht - Attached On 2018-09-06 18:03:07 UTC - Size: 30.7 KB - 287 views |
[2018-09-06 18:47:15] |
ticinotrader - Posts: 400 |
I am having the same issue: there are no enclosing bars drawn since updated to the latest versions from 1784. I can also send a chartbook if needed. Right now I am on SC v1798. Thank you. |
[2018-09-06 22:25:50] |
The problem is when using Transparancy mode. When transparency is turned off the bounding box shows up. We will solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
