Date/Time: Wed, 22 Jan 2025 04:30:52 +0000
Odd MSG While Logged In
View Count: 602
[2018-09-05 01:17:02] |
User180126 - Posts: 12 |
I keep getting this weird message on the message log every min or so that has just started this evening. Do you know what this is refferring to? See Attached |
[2018-09-05 02:27:15] |
This is explained here: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Resolving DTC Protocol Server Port Number Conflicts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-05 02:35:35] |
Thank You I must have had a separate instance running
