Date/Time: Wed, 22 Jan 2025 04:40:42 +0000
After an Update My Charts do not load anymore
View Count: 1141
[2018-09-04 22:34:04] |
196988 - Posts: 2 |
Dear support team, after an update from Version 1727 to 1795 I can only use Rithmic Charts. All my Forex Charts do not load (Symbol is unknown click for symbol information). Meanwhile hours are gone and I have no idea how to solve this problem. Thanks for your help! |
[2018-09-05 01:14:49] |
Tell us one of the chart symbols you are having a problem with and then follow the instructions below. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-05 02:00:47] |
196988 - Posts: 2 |
Software version: 1795 32-bit | 2018-09-05 03:48:36 Usage end date: 2018-12-30 | 2018-09-05 03:48:36 Enabled for: Advanced Features. | 2018-09-05 03:48:36 Enabled for: Sierra Chart Historical Data Service. | 2018-09-05 03:48:36 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-09-05 03:48:36 Current selected Data/Trading service: Rithmic Trading | 2018-09-05 03:48:36 Chart Update Interval: 100 | 2018-09-05 03:48:36 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2018-09-05 03:48:36 2018-09-05 03:48:36 Local computer time | 2018-09-05 03:48:36 2018-09-05 01:48:36 Local computer time in UTC | 2018-09-05 03:48:36 2018-09-05 03:48:36 Local computer time in SC Time Zone | 2018-09-05 03:48:36 2018-09-04 22:22:48 Server time in UTC | 2018-09-05 03:48:36 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-09-05 03:48:36 Program path: C:\SierraChart\ | 2018-09-05 03:48:36 Data Files path: C:\SierraChart\Data\ | 2018-09-05 03:48:36 OS Version Number: 10.0 | 2018-09-05 03:48:36 Locale Setting: C | 2018-09-05 03:48:36 File >> Disconnect selected. | 2018-09-05 03:49:31 DTC Client socket (10) | 1144 bytes remaining in receive buffer when socket closed. | 2018-09-05 03:49:33 DTC Client socket (10) | Initiating close of socket by core. | 2018-09-05 03:49:33 DTC Client socket (10) | Shutdown started. Waiting for graceful close. | 2018-09-05 03:49:33 DTC Client socket (10) | Socket gracefully closed by remote side. | 2018-09-05 03:49:33 DTC Client socket (10) | Closed. | 2018-09-05 03:49:33 Rithmic Trading | Disconnected. | 2018-09-05 03:49:33 Rithmic Trading | Port for executable: 50596 | 2018-09-05 03:49:48 Listening socket (2236). Port 50596 | Closed. | 2018-09-05 03:49:48 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-09-05 03:49:48 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50596. Current folder: C:\SierraChart\Rim | 2018-09-05 03:49:48 Rithmic Trading | Bridge process is not running! | 2018-09-05 03:49:50 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50596 | 2018-09-05 03:49:50 DTC Client socket (240) | Creating socket. | 2018-09-05 03:49:50 DTC Client socket (240) | Connecting to IP: 127.0.0.1. | 2018-09-05 03:49:50 DTC Client socket (240) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2018-09-05 03:49:51 * DTC Client socket (240) | Initiating close of socket by core. | 2018-09-05 03:49:51 DTC Client socket (240) | Closed. | 2018-09-05 03:49:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-05 03:49:51 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 03:49:51 Rithmic Trading | Disconnected. | 2018-09-05 03:49:51 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-05 03:49:51 Rithmic Trading | Port for executable: 50599 | 2018-09-05 03:49:53 Listening socket (936). Port 50599 | Closed. | 2018-09-05 03:49:53 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-09-05 03:49:53 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50599. Current folder: C:\SierraChart\Rim | 2018-09-05 03:49:53 Rithmic Trading | Bridge process is running. | 2018-09-05 03:49:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50599 | 2018-09-05 03:49:55 DTC Client socket (241) | Creating socket. | 2018-09-05 03:49:55 DTC Client socket (241) | Connecting to IP: 127.0.0.1. | 2018-09-05 03:49:55 Rithmic Trading | Connected to server. | 2018-09-05 03:49:55 Rithmic Trading | Starting socket receive thread. | 2018-09-05 03:49:55 Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-09-05 03:49:55 Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-09-05 03:49:55 Rithmic Trading | Sending logon request message. | 2018-09-05 03:49:55 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-09-05 03:49:55 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-09-05 03:49:55 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-09-05 03:49:55 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-09-05 03:49:56 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2018-09-05 03:49:56 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2018-09-05 03:49:57 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2018-09-05 03:49:57 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2018-09-05 03:49:58 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2018-09-05 03:49:58 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2018-09-05 03:49:59 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2018-09-05 03:49:59 Rithmic Trading | Received logon response. | 2018-09-05 03:49:59 Rithmic Trading | Server Name: SC DTC Bridge. | 2018-09-05 03:49:59 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-09-05 03:49:59 Rithmic Trading | Successfully connected. IB='Stage5', Firm='Dorman'. | 2018-09-05 03:49:59 Rithmic Trading | Trading is supported. | 2018-09-05 03:49:59 Rithmic Trading | Order cancel and replace is supported. | 2018-09-05 03:49:59 Rithmic Trading | OCO Orders supported. | 2018-09-05 03:49:59 Rithmic Trading | Connected to data and trading server. | 2018-09-05 03:49:59 HD Server | New server thread for client has been created for incoming connection. | 2018-09-05 03:49:59 Socket (242) | Creating socket. | 2018-09-05 03:49:59 HD Server | Setting DTC encoding to Binary VLS | 2018-09-05 03:49:59 HD Server | Received login. Requesting authorization. | Username: namsom. | 2018-09-05 03:49:59 HD Server | Login has been authorized. | Username: namsom. | 2018-09-05 03:49:59 HD Server | HD Request #13 | Socket: 242 | Symbol: ZFZ8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | MaximumDaysRequested: 0 | Start date-time: 2018-09-05 01:49:05 | ClientRequestID: 13 | Username: namsom. | 2018-09-05 03:49:59 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZFZ8-CBOT | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: ZFZ8-CBOT. ID: 1 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: ZFZ8-CBOT. ID: 1 | 2018-09-05 03:49:59 Delaying start of download for ZFZ8-CBOT | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for USDCHF | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: USDCHF. ID: 2 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: USDCHF. ID: 2 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for USDCHF | 2018-09-05 03:49:59 Intraday data recording state for symbol USDCHF is set to download 'Pending'. | 2018-09-05 03:49:59 Delaying start of download for USDCHF | 2018-09-05 03:49:59 Symbol Error - USDCHF is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for NAS100 | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: NAS100. ID: 3 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: NAS100. ID: 3 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for NAS100 | 2018-09-05 03:49:59 Intraday data recording state for symbol NAS100 is set to download 'Pending'. | 2018-09-05 03:49:59 Symbol Error - NAS100 is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for EUSTX50 | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: EUSTX50. ID: 4 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: EUSTX50. ID: 4 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for EUSTX50 | 2018-09-05 03:49:59 Intraday data recording state for symbol EUSTX50 is set to download 'Pending'. | 2018-09-05 03:49:59 Symbol Error - EUSTX50 is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: YMU8-CBOT. ID: 5 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: YMU8-CBOT. ID: 5 | 2018-09-05 03:49:59 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMU8-CBOT | 2018-09-05 03:49:59 Intraday data recording state for symbol YMU8-CBOT is set to download 'Pending'. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for JPN225 | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: JPN225. ID: 6 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: JPN225. ID: 6 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for JPN225 | 2018-09-05 03:49:59 Intraday data recording state for symbol JPN225 is set to download 'Pending'. | 2018-09-05 03:49:59 Symbol Error - JPN225 is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for SPX500 | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: SPX500. ID: 7 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: SPX500. ID: 7 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for SPX500 | 2018-09-05 03:49:59 Intraday data recording state for symbol SPX500 is set to download 'Pending'. | 2018-09-05 03:49:59 Symbol Error - SPX500 is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for AUS200 | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: AUS200. ID: 8 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: AUS200. ID: 8 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for AUS200 | 2018-09-05 03:49:59 Intraday data recording state for symbol AUS200 is set to download 'Pending'. | 2018-09-05 03:49:59 Symbol Error - AUS200 is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: ZNZ8-CBOT. ID: 9 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: ZNZ8-CBOT. ID: 9 | 2018-09-05 03:49:59 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZNZ8-CBOT | 2018-09-05 03:49:59 Intraday data recording state for symbol ZNZ8-CBOT is set to download 'Pending'. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for GBPUSD | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: GBPUSD. ID: 10 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: GBPUSD. ID: 10 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for GBPUSD | 2018-09-05 03:49:59 Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2018-09-05 03:49:59 Symbol Error - GBPUSD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for USDJPY | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: USDJPY. ID: 11 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: USDJPY. ID: 11 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for USDJPY | 2018-09-05 03:49:59 Intraday data recording state for symbol USDJPY is set to download 'Pending'. | 2018-09-05 03:49:59 Symbol Error - USDJPY is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for EURUSD | 2018-09-05 03:49:59 Rithmic Trading | Starting real-time market data updates for: EURUSD. ID: 12 | 2018-09-05 03:49:59 Rithmic Trading | Requesting security definition data for: EURUSD. ID: 12 | 2018-09-05 03:49:59 Rithmic Trading | Using primary service for historical data for EURUSD | 2018-09-05 03:49:59 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2018-09-05 03:49:59 Symbol Error - EURUSD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:49:59 Using Bid/Ask average for last trade price for EURAUD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: EURAUD. ID: 13 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: EURAUD. ID: 13 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for EURAUD | 2018-09-05 03:50:00 Intraday data recording state for symbol EURAUD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - EURAUD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for GBPAUD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: GBPAUD. ID: 14 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: GBPAUD. ID: 14 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for GBPAUD | 2018-09-05 03:50:00 Intraday data recording state for symbol GBPAUD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - GBPAUD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for NZDJPY | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: NZDJPY. ID: 15 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: NZDJPY. ID: 15 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for NZDJPY | 2018-09-05 03:50:00 Intraday data recording state for symbol NZDJPY is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - NZDJPY is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for CHFJPY | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: CHFJPY. ID: 16 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: CHFJPY. ID: 16 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for CHFJPY | 2018-09-05 03:50:00 Intraday data recording state for symbol CHFJPY is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - CHFJPY is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for NZDCAD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: NZDCAD. ID: 17 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: NZDCAD. ID: 17 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for NZDCAD | 2018-09-05 03:50:00 Intraday data recording state for symbol NZDCAD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - NZDCAD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for AUDCHF | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: AUDCHF. ID: 18 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: AUDCHF. ID: 18 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for AUDCHF | 2018-09-05 03:50:00 Intraday data recording state for symbol AUDCHF is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - AUDCHF is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for NZDCHF | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: NZDCHF. ID: 19 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: NZDCHF. ID: 19 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for NZDCHF | 2018-09-05 03:50:00 Intraday data recording state for symbol NZDCHF is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - NZDCHF is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for EURJPY | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: EURJPY. ID: 20 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: EURJPY. ID: 20 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for EURJPY | 2018-09-05 03:50:00 Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - EURJPY is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for GBPCAD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: GBPCAD. ID: 21 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: GBPCAD. ID: 21 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for GBPCAD | 2018-09-05 03:50:00 Intraday data recording state for symbol GBPCAD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - GBPCAD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for CADJPY | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: CADJPY. ID: 22 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: CADJPY. ID: 22 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for CADJPY | 2018-09-05 03:50:00 Intraday data recording state for symbol CADJPY is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - CADJPY is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for EURGBP | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: EURGBP. ID: 23 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: EURGBP. ID: 23 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for EURGBP | 2018-09-05 03:50:00 Intraday data recording state for symbol EURGBP is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - EURGBP is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for GBPCHF | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: GBPCHF. ID: 24 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: GBPCHF. ID: 24 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for GBPCHF | 2018-09-05 03:50:00 Intraday data recording state for symbol GBPCHF is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - GBPCHF is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for XAUUSD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: XAUUSD. ID: 25 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: XAUUSD. ID: 25 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for XAUUSD | 2018-09-05 03:50:00 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - XAUUSD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for AUDCAD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: AUDCAD. ID: 26 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: AUDCAD. ID: 26 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for AUDCAD | 2018-09-05 03:50:00 Intraday data recording state for symbol AUDCAD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - AUDCAD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for GBPJPY | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: GBPJPY. ID: 27 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: GBPJPY. ID: 27 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for GBPJPY | 2018-09-05 03:50:00 Intraday data recording state for symbol GBPJPY is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - GBPJPY is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for UK100 | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: UK100. ID: 28 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: UK100. ID: 28 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for UK100 | 2018-09-05 03:50:00 Intraday data recording state for symbol UK100 is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - UK100 is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for GER30 | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: GER30. ID: 29 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: GER30. ID: 29 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for GER30 | 2018-09-05 03:50:00 Intraday data recording state for symbol GER30 is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - GER30 is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for NZDUSD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: NZDUSD. ID: 30 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: NZDUSD. ID: 30 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for NZDUSD | 2018-09-05 03:50:00 Intraday data recording state for symbol NZDUSD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - NZDUSD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for AUDUSD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: AUDUSD. ID: 31 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: AUDUSD. ID: 31 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for AUDUSD | 2018-09-05 03:50:00 Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - AUDUSD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for EURNZD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: EURNZD. ID: 32 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: EURNZD. ID: 32 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for EURNZD | 2018-09-05 03:50:00 Intraday data recording state for symbol EURNZD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - EURNZD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for GBPNZD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: GBPNZD. ID: 33 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: GBPNZD. ID: 33 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for GBPNZD | 2018-09-05 03:50:00 Intraday data recording state for symbol GBPNZD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - GBPNZD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for USDCAD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: USDCAD. ID: 34 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: USDCAD. ID: 34 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for USDCAD | 2018-09-05 03:50:00 Intraday data recording state for symbol USDCAD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - USDCAD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: CLV8-NYMEX. ID: 35 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: CLV8-NYMEX. ID: 35 | 2018-09-05 03:50:00 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLV8-NYMEX | 2018-09-05 03:50:00 Intraday data recording state for symbol CLV8-NYMEX is set to download 'Pending'. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for AUDNZD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: AUDNZD. ID: 36 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: AUDNZD. ID: 36 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for AUDNZD | 2018-09-05 03:50:00 Intraday data recording state for symbol AUDNZD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - AUDNZD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for CADCHF | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: CADCHF. ID: 37 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: CADCHF. ID: 37 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for CADCHF | 2018-09-05 03:50:00 Intraday data recording state for symbol CADCHF is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - CADCHF is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for HKG33 | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: HKG33. ID: 38 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: HKG33. ID: 38 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for HKG33 | 2018-09-05 03:50:00 Intraday data recording state for symbol HKG33 is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - HKG33 is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for AUDJPY | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: AUDJPY. ID: 39 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: AUDJPY. ID: 39 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for AUDJPY | 2018-09-05 03:50:00 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - AUDJPY is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for EURCHF | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: EURCHF. ID: 40 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: EURCHF. ID: 40 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for EURCHF | 2018-09-05 03:50:00 Intraday data recording state for symbol EURCHF is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - EURCHF is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Using Bid/Ask average for last trade price for EURCAD | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: EURCAD. ID: 41 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: EURCAD. ID: 41 | 2018-09-05 03:50:00 Rithmic Trading | Using primary service for historical data for EURCAD | 2018-09-05 03:50:00 Intraday data recording state for symbol EURCAD is set to download 'Pending'. | 2018-09-05 03:50:00 Symbol Error - EURCAD is unknown, unavailable, or improperly formatted. | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: ZBZ8-CBOT. ID: 42 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: ZBZ8-CBOT. ID: 42 | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: NGV8-NYMEX. ID: 43 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: NGV8-NYMEX. ID: 43 | 2018-09-05 03:50:00 Rithmic Trading | Starting real-time market data updates for: UBZ8-CBOT. ID: 44 | 2018-09-05 03:50:00 Rithmic Trading | Requesting security definition data for: UBZ8-CBOT. ID: 44 | 2018-09-05 03:50:00 Requesting market depth updates for: ZFZ8-CBOT if supported. | 2018-09-05 03:50:00 Requesting market depth updates for: ZNZ8-CBOT if supported. | 2018-09-05 03:50:00 Requesting market depth updates for: ZBZ8-CBOT if supported. | 2018-09-05 03:50:00 Requesting market depth updates for: NGV8-NYMEX if supported. | 2018-09-05 03:50:00 Requesting market depth updates for: CLV8-NYMEX if supported. | 2018-09-05 03:50:00 Requesting market depth updates for: YMU8-CBOT if supported. | 2018-09-05 03:50:00 Requesting market depth updates for: UBZ8-CBOT if supported. | 2018-09-05 03:50:00 HD Request # 59 | Downloading Intraday chart data for USDCHF to the file USDCHF.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 59 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:00 HD Request # 59 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: USDCHF | 2018-09-05 03:50:00 HD Request # 59 | Error downloading historical Intraday data for USDCHF. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 59 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USDCHF | 2018-09-05 03:50:00 HD Request # 59 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 59 | Intraday data download complete for USDCHF. Unique request ID: 62 | 2018-09-05 03:50:00 Removed historical data download ID 62 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for USDCHF | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\USDCHF.scid | 2018-09-05 03:50:00 Intraday chart data file opened for USDCHF | 2018-09-05 03:50:00 HD Request # 60 | Downloading Intraday chart data for NAS100 to the file NAS100.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 60 | Download start date-time: 2018-09-04 22:59:00.000 | 2018-09-05 03:50:00 HD Request # 60 | Sending historical data request. Start date-time: 2018-09-04 22:59:00. Record interval: 60. Symbol: NAS100 | 2018-09-05 03:50:00 HD Request # 60 | Error downloading historical Intraday data for NAS100. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 60 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NAS100 | 2018-09-05 03:50:00 HD Request # 60 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 60 | Intraday data download complete for NAS100. Unique request ID: 63 | 2018-09-05 03:50:00 Removed historical data download ID 63 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for NAS100 | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\NAS100.scid | 2018-09-05 03:50:00 Intraday chart data file opened for NAS100 | 2018-09-05 03:50:00 HD Request # 61 | Downloading Intraday chart data for EUSTX50 to the file EUSTX50.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 61 | Download start date-time: 2018-09-04 21:59:09.000 | 2018-09-05 03:50:00 HD Request # 61 | Sending historical data request. Start date-time: 2018-09-04 21:59:09. Record interval: 60. Symbol: EUSTX50 | 2018-09-05 03:50:00 HD Request # 61 | Error downloading historical Intraday data for EUSTX50. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 61 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EUSTX50 | 2018-09-05 03:50:00 HD Request # 61 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 61 | Intraday data download complete for EUSTX50. Unique request ID: 64 | 2018-09-05 03:50:00 Removed historical data download ID 64 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for EUSTX50 | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\EUSTX50.scid | 2018-09-05 03:50:00 Intraday chart data file opened for EUSTX50 | 2018-09-05 03:50:00 HD Request # 62 | Downloading Intraday chart data for JPN225 to the file JPN225.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 62 | Download start date-time: 2018-09-04 22:14:03.000 | 2018-09-05 03:50:00 HD Request # 62 | Sending historical data request. Start date-time: 2018-09-04 22:14:03. Record interval: 60. Symbol: JPN225 | 2018-09-05 03:50:00 HD Request # 62 | Error downloading historical Intraday data for JPN225. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 62 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for JPN225 | 2018-09-05 03:50:00 HD Request # 62 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 62 | Intraday data download complete for JPN225. Unique request ID: 66 | 2018-09-05 03:50:00 Removed historical data download ID 66 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for JPN225 | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\JPN225.scid | 2018-09-05 03:50:00 Intraday chart data file opened for JPN225 | 2018-09-05 03:50:00 HD Request # 63 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 63 | Download start date-time: 2018-09-04 22:59:00.000 | 2018-09-05 03:50:00 HD Request # 63 | Sending historical data request. Start date-time: 2018-09-04 22:59:00. Record interval: 60. Symbol: SPX500 | 2018-09-05 03:50:00 HD Request # 63 | Error downloading historical Intraday data for SPX500. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 63 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SPX500 | 2018-09-05 03:50:00 HD Request # 63 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 63 | Intraday data download complete for SPX500. Unique request ID: 67 | 2018-09-05 03:50:00 Removed historical data download ID 67 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for SPX500 | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\SPX500.scid | 2018-09-05 03:50:00 Intraday chart data file opened for SPX500 | 2018-09-05 03:50:00 HD Request # 64 | Downloading Intraday chart data for AUS200 to the file AUS200.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 64 | Download start date-time: 2018-08-07 03:00:01.000 | 2018-09-05 03:50:00 HD Request # 64 | Sending historical data request. Start date-time: 2018-08-07 03:00:01. Record interval: 60. Symbol: AUS200 | 2018-09-05 03:50:00 HD Request # 64 | Error downloading historical Intraday data for AUS200. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 64 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUS200 | 2018-09-05 03:50:00 HD Request # 64 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 64 | Intraday data download complete for AUS200. Unique request ID: 68 | 2018-09-05 03:50:00 Removed historical data download ID 68 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for AUS200 | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\AUS200.scid | 2018-09-05 03:50:00 Intraday chart data file opened for AUS200 | 2018-09-05 03:50:00 HD Request # 65 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 65 | Download start date-time: 2018-09-04 23:53:10.000 | 2018-09-05 03:50:00 HD Request # 65 | Sending historical data request. Start date-time: 2018-09-04 23:53:10. Record interval: 60. Symbol: GBPUSD | 2018-09-05 03:50:00 HD Request # 65 | Error downloading historical Intraday data for GBPUSD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 65 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPUSD | 2018-09-05 03:50:00 HD Request # 65 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 65 | Intraday data download complete for GBPUSD. Unique request ID: 70 | 2018-09-05 03:50:00 Removed historical data download ID 70 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for GBPUSD | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\GBPUSD.scid | 2018-09-05 03:50:00 Intraday chart data file opened for GBPUSD | 2018-09-05 03:50:00 HD Request # 66 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 66 | Download start date-time: 2018-09-04 23:53:00.000 | 2018-09-05 03:50:00 HD Request # 66 | Sending historical data request. Start date-time: 2018-09-04 23:53:00. Record interval: 60. Symbol: USDJPY | 2018-09-05 03:50:00 HD Request # 66 | Error downloading historical Intraday data for USDJPY. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 66 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USDJPY | 2018-09-05 03:50:00 HD Request # 66 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 66 | Intraday data download complete for USDJPY. Unique request ID: 71 | 2018-09-05 03:50:00 Removed historical data download ID 71 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for USDJPY | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\USDJPY.scid | 2018-09-05 03:50:00 Intraday chart data file opened for USDJPY | 2018-09-05 03:50:00 HD Request # 67 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 67 | Download start date-time: 2018-09-04 23:53:00.000 | 2018-09-05 03:50:00 HD Request # 67 | Sending historical data request. Start date-time: 2018-09-04 23:53:00. Record interval: 60. Symbol: EURUSD | 2018-09-05 03:50:00 HD Request # 67 | Error downloading historical Intraday data for EURUSD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 67 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURUSD | 2018-09-05 03:50:00 HD Request # 67 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 67 | Intraday data download complete for EURUSD. Unique request ID: 72 | 2018-09-05 03:50:00 Removed historical data download ID 72 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for EURUSD | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid | 2018-09-05 03:50:00 Intraday chart data file opened for EURUSD | 2018-09-05 03:50:00 HD Request # 68 | Downloading Intraday chart data for EURAUD to the file EURAUD.scid. Service: fxcm | 2018-09-05 03:50:00 HD Request # 68 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:00 HD Request # 68 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: EURAUD | 2018-09-05 03:50:00 HD Request # 68 | Error downloading historical Intraday data for EURAUD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:00 HD Request # 68 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURAUD | 2018-09-05 03:50:00 HD Request # 68 | Completion time: 0s | 2018-09-05 03:50:00 HD Request # 68 | Intraday data download complete for EURAUD. Unique request ID: 73 | 2018-09-05 03:50:00 Removed historical data download ID 73 | 2018-09-05 03:50:00 Real-time Intraday chart data file updates started for EURAUD | 2018-09-05 03:50:00 Opened cached Intraday file: C:\SierraChart\Data\EURAUD.scid | 2018-09-05 03:50:00 Intraday chart data file opened for EURAUD | 2018-09-05 03:50:00 HD Request # 69 | Downloading Intraday chart data for GBPAUD to the file GBPAUD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 69 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 69 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: GBPAUD | 2018-09-05 03:50:01 HD Request # 69 | Error downloading historical Intraday data for GBPAUD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 69 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPAUD | 2018-09-05 03:50:01 HD Request # 69 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 69 | Intraday data download complete for GBPAUD. Unique request ID: 74 | 2018-09-05 03:50:01 Removed historical data download ID 74 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for GBPAUD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\GBPAUD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for GBPAUD | 2018-09-05 03:50:01 HD Request # 70 | Downloading Intraday chart data for NZDJPY to the file NZDJPY.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 70 | Download start date-time: 2018-09-04 23:53:04.000 | 2018-09-05 03:50:01 HD Request # 70 | Sending historical data request. Start date-time: 2018-09-04 23:53:04. Record interval: 60. Symbol: NZDJPY | 2018-09-05 03:50:01 HD Request # 70 | Error downloading historical Intraday data for NZDJPY. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 70 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NZDJPY | 2018-09-05 03:50:01 HD Request # 70 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 70 | Intraday data download complete for NZDJPY. Unique request ID: 75 | 2018-09-05 03:50:01 Removed historical data download ID 75 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for NZDJPY | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\NZDJPY.scid | 2018-09-05 03:50:01 Intraday chart data file opened for NZDJPY | 2018-09-05 03:50:01 HD Request # 71 | Downloading Intraday chart data for CHFJPY to the file CHFJPY.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 71 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 71 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: CHFJPY | 2018-09-05 03:50:01 HD Request # 71 | Error downloading historical Intraday data for CHFJPY. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 71 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CHFJPY | 2018-09-05 03:50:01 HD Request # 71 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 71 | Intraday data download complete for CHFJPY. Unique request ID: 76 | 2018-09-05 03:50:01 Removed historical data download ID 76 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for CHFJPY | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\CHFJPY.scid | 2018-09-05 03:50:01 Intraday chart data file opened for CHFJPY | 2018-09-05 03:50:01 HD Request # 72 | Downloading Intraday chart data for NZDCAD to the file NZDCAD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 72 | Download start date-time: 2018-09-04 23:53:02.000 | 2018-09-05 03:50:01 HD Request # 72 | Sending historical data request. Start date-time: 2018-09-04 23:53:02. Record interval: 60. Symbol: NZDCAD | 2018-09-05 03:50:01 HD Request # 72 | Error downloading historical Intraday data for NZDCAD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 72 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NZDCAD | 2018-09-05 03:50:01 HD Request # 72 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 72 | Intraday data download complete for NZDCAD. Unique request ID: 77 | 2018-09-05 03:50:01 Removed historical data download ID 77 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for NZDCAD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\NZDCAD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for NZDCAD | 2018-09-05 03:50:01 HD Request # 73 | Downloading Intraday chart data for AUDCHF to the file AUDCHF.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 73 | Download start date-time: 2018-09-04 23:54:01.000 | 2018-09-05 03:50:01 HD Request # 73 | Sending historical data request. Start date-time: 2018-09-04 23:54:01. Record interval: 60. Symbol: AUDCHF | 2018-09-05 03:50:01 HD Request # 73 | Error downloading historical Intraday data for AUDCHF. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 73 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDCHF | 2018-09-05 03:50:01 HD Request # 73 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 73 | Intraday data download complete for AUDCHF. Unique request ID: 78 | 2018-09-05 03:50:01 Removed historical data download ID 78 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for AUDCHF | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\AUDCHF.scid | 2018-09-05 03:50:01 Intraday chart data file opened for AUDCHF | 2018-09-05 03:50:01 HD Request # 74 | Downloading Intraday chart data for NZDCHF to the file NZDCHF.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 74 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 74 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: NZDCHF | 2018-09-05 03:50:01 HD Request # 74 | Error downloading historical Intraday data for NZDCHF. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 74 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NZDCHF | 2018-09-05 03:50:01 HD Request # 74 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 74 | Intraday data download complete for NZDCHF. Unique request ID: 79 | 2018-09-05 03:50:01 Removed historical data download ID 79 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for NZDCHF | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\NZDCHF.scid | 2018-09-05 03:50:01 Intraday chart data file opened for NZDCHF | 2018-09-05 03:50:01 HD Request # 75 | Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 75 | Download start date-time: 2018-09-04 23:53:00.000 | 2018-09-05 03:50:01 HD Request # 75 | Sending historical data request. Start date-time: 2018-09-04 23:53:00. Record interval: 60. Symbol: EURJPY | 2018-09-05 03:50:01 HD Request # 75 | Error downloading historical Intraday data for EURJPY. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 75 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURJPY | 2018-09-05 03:50:01 HD Request # 75 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 75 | Intraday data download complete for EURJPY. Unique request ID: 80 | 2018-09-05 03:50:01 Removed historical data download ID 80 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for EURJPY | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\EURJPY.scid | 2018-09-05 03:50:01 Intraday chart data file opened for EURJPY | 2018-09-05 03:50:01 HD Request # 76 | Downloading Intraday chart data for GBPCAD to the file GBPCAD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 76 | Download start date-time: 2018-09-04 23:54:09.000 | 2018-09-05 03:50:01 HD Request # 76 | Sending historical data request. Start date-time: 2018-09-04 23:54:09. Record interval: 60. Symbol: GBPCAD | 2018-09-05 03:50:01 HD Request # 76 | Error downloading historical Intraday data for GBPCAD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 76 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPCAD | 2018-09-05 03:50:01 HD Request # 76 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 76 | Intraday data download complete for GBPCAD. Unique request ID: 81 | 2018-09-05 03:50:01 Removed historical data download ID 81 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for GBPCAD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\GBPCAD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for GBPCAD | 2018-09-05 03:50:01 HD Request # 77 | Downloading Intraday chart data for CADJPY to the file CADJPY.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 77 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 77 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: CADJPY | 2018-09-05 03:50:01 HD Request # 77 | Error downloading historical Intraday data for CADJPY. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 77 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CADJPY | 2018-09-05 03:50:01 HD Request # 77 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 77 | Intraday data download complete for CADJPY. Unique request ID: 82 | 2018-09-05 03:50:01 Removed historical data download ID 82 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for CADJPY | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\CADJPY.scid | 2018-09-05 03:50:01 Intraday chart data file opened for CADJPY | 2018-09-05 03:50:01 HD Request # 78 | Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 78 | Download start date-time: 2018-09-04 23:54:04.000 | 2018-09-05 03:50:01 HD Request # 78 | Sending historical data request. Start date-time: 2018-09-04 23:54:04. Record interval: 60. Symbol: EURGBP | 2018-09-05 03:50:01 HD Request # 78 | Error downloading historical Intraday data for EURGBP. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 78 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURGBP | 2018-09-05 03:50:01 HD Request # 78 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 78 | Intraday data download complete for EURGBP. Unique request ID: 83 | 2018-09-05 03:50:01 Removed historical data download ID 83 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for EURGBP | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\EURGBP.scid | 2018-09-05 03:50:01 Intraday chart data file opened for EURGBP | 2018-09-05 03:50:01 HD Request # 79 | Downloading Intraday chart data for GBPCHF to the file GBPCHF.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 79 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 79 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: GBPCHF | 2018-09-05 03:50:01 HD Request # 79 | Error downloading historical Intraday data for GBPCHF. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 79 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPCHF | 2018-09-05 03:50:01 HD Request # 79 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 79 | Intraday data download complete for GBPCHF. Unique request ID: 84 | 2018-09-05 03:50:01 Removed historical data download ID 84 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for GBPCHF | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\GBPCHF.scid | 2018-09-05 03:50:01 Intraday chart data file opened for GBPCHF | 2018-09-05 03:50:01 HD Request # 80 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 80 | Download start date-time: 2018-09-04 22:58:00.000 | 2018-09-05 03:50:01 HD Request # 80 | Sending historical data request. Start date-time: 2018-09-04 22:58:00. Record interval: 60. Symbol: XAUUSD | 2018-09-05 03:50:01 HD Request # 80 | Error downloading historical Intraday data for XAUUSD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 80 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for XAUUSD | 2018-09-05 03:50:01 HD Request # 80 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 80 | Intraday data download complete for XAUUSD. Unique request ID: 85 | 2018-09-05 03:50:01 Removed historical data download ID 85 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for XAUUSD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for XAUUSD | 2018-09-05 03:50:01 HD Request # 81 | Downloading Intraday chart data for AUDCAD to the file AUDCAD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 81 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 81 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: AUDCAD | 2018-09-05 03:50:01 HD Request # 81 | Error downloading historical Intraday data for AUDCAD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 81 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDCAD | 2018-09-05 03:50:01 HD Request # 81 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 81 | Intraday data download complete for AUDCAD. Unique request ID: 86 | 2018-09-05 03:50:01 Removed historical data download ID 86 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for AUDCAD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\AUDCAD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for AUDCAD | 2018-09-05 03:50:01 HD Request # 82 | Downloading Intraday chart data for GBPJPY to the file GBPJPY.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 82 | Download start date-time: 2018-09-04 23:53:15.000 | 2018-09-05 03:50:01 HD Request # 82 | Sending historical data request. Start date-time: 2018-09-04 23:53:15. Record interval: 60. Symbol: GBPJPY | 2018-09-05 03:50:01 HD Request # 82 | Error downloading historical Intraday data for GBPJPY. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 82 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPJPY | 2018-09-05 03:50:01 HD Request # 82 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 82 | Intraday data download complete for GBPJPY. Unique request ID: 87 | 2018-09-05 03:50:01 Removed historical data download ID 87 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for GBPJPY | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\GBPJPY.scid | 2018-09-05 03:50:01 Intraday chart data file opened for GBPJPY | 2018-09-05 03:50:01 HD Request # 83 | Downloading Intraday chart data for UK100 to the file UK100.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 83 | Download start date-time: 2018-09-04 21:59:07.000 | 2018-09-05 03:50:01 HD Request # 83 | Sending historical data request. Start date-time: 2018-09-04 21:59:07. Record interval: 60. Symbol: UK100 | 2018-09-05 03:50:01 HD Request # 83 | Error downloading historical Intraday data for UK100. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 83 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for UK100 | 2018-09-05 03:50:01 HD Request # 83 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 83 | Intraday data download complete for UK100. Unique request ID: 88 | 2018-09-05 03:50:01 Removed historical data download ID 88 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for UK100 | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\UK100.scid | 2018-09-05 03:50:01 Intraday chart data file opened for UK100 | 2018-09-05 03:50:01 HD Request # 84 | Downloading Intraday chart data for GER30 to the file GER30.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 84 | Download start date-time: 2018-09-04 21:59:01.000 | 2018-09-05 03:50:01 HD Request # 84 | Sending historical data request. Start date-time: 2018-09-04 21:59:01. Record interval: 60. Symbol: GER30 | 2018-09-05 03:50:01 HD Request # 84 | Error downloading historical Intraday data for GER30. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 84 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GER30 | 2018-09-05 03:50:01 HD Request # 84 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 84 | Intraday data download complete for GER30. Unique request ID: 89 | 2018-09-05 03:50:01 Removed historical data download ID 89 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for GER30 | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\GER30.scid | 2018-09-05 03:50:01 Intraday chart data file opened for GER30 | 2018-09-05 03:50:01 HD Request # 85 | Downloading Intraday chart data for NZDUSD to the file NZDUSD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 85 | Download start date-time: 2018-09-04 23:53:02.000 | 2018-09-05 03:50:01 HD Request # 85 | Sending historical data request. Start date-time: 2018-09-04 23:53:02. Record interval: 60. Symbol: NZDUSD | 2018-09-05 03:50:01 HD Request # 85 | Error downloading historical Intraday data for NZDUSD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 85 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NZDUSD | 2018-09-05 03:50:01 HD Request # 85 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 85 | Intraday data download complete for NZDUSD. Unique request ID: 90 | 2018-09-05 03:50:01 Removed historical data download ID 90 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for NZDUSD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\NZDUSD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for NZDUSD | 2018-09-05 03:50:01 HD Request # 86 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 86 | Download start date-time: 2018-09-04 23:53:00.000 | 2018-09-05 03:50:01 HD Request # 86 | Sending historical data request. Start date-time: 2018-09-04 23:53:00. Record interval: 60. Symbol: AUDUSD | 2018-09-05 03:50:01 HD Request # 86 | Error downloading historical Intraday data for AUDUSD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 86 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDUSD | 2018-09-05 03:50:01 HD Request # 86 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 86 | Intraday data download complete for AUDUSD. Unique request ID: 91 | 2018-09-05 03:50:01 Removed historical data download ID 91 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for AUDUSD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\AUDUSD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for AUDUSD | 2018-09-05 03:50:01 HD Request # 87 | Downloading Intraday chart data for EURNZD to the file EURNZD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 87 | Download start date-time: 2018-09-04 23:54:01.000 | 2018-09-05 03:50:01 HD Request # 87 | Sending historical data request. Start date-time: 2018-09-04 23:54:01. Record interval: 60. Symbol: EURNZD | 2018-09-05 03:50:01 HD Request # 87 | Error downloading historical Intraday data for EURNZD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 87 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURNZD | 2018-09-05 03:50:01 HD Request # 87 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 87 | Intraday data download complete for EURNZD. Unique request ID: 92 | 2018-09-05 03:50:01 Removed historical data download ID 92 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for EURNZD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\EURNZD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for EURNZD | 2018-09-05 03:50:01 HD Request # 88 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 88 | Download start date-time: 2018-09-04 23:54:07.000 | 2018-09-05 03:50:01 HD Request # 88 | Sending historical data request. Start date-time: 2018-09-04 23:54:07. Record interval: 60. Symbol: GBPNZD | 2018-09-05 03:50:01 HD Request # 88 | Error downloading historical Intraday data for GBPNZD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 88 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPNZD | 2018-09-05 03:50:01 HD Request # 88 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 88 | Intraday data download complete for GBPNZD. Unique request ID: 93 | 2018-09-05 03:50:01 Removed historical data download ID 93 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for GBPNZD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\GBPNZD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for GBPNZD | 2018-09-05 03:50:01 HD Request # 89 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 89 | Download start date-time: 2018-09-04 23:53:01.000 | 2018-09-05 03:50:01 HD Request # 89 | Sending historical data request. Start date-time: 2018-09-04 23:53:01. Record interval: 60. Symbol: USDCAD | 2018-09-05 03:50:01 HD Request # 89 | Error downloading historical Intraday data for USDCAD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 89 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for USDCAD | 2018-09-05 03:50:01 HD Request # 89 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 89 | Intraday data download complete for USDCAD. Unique request ID: 94 | 2018-09-05 03:50:01 Removed historical data download ID 94 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for USDCAD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\USDCAD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for USDCAD | 2018-09-05 03:50:01 HD Request # 90 | Downloading Intraday chart data for AUDNZD to the file AUDNZD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 90 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 90 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: AUDNZD | 2018-09-05 03:50:01 HD Request # 90 | Error downloading historical Intraday data for AUDNZD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 90 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDNZD | 2018-09-05 03:50:01 HD Request # 90 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 90 | Intraday data download complete for AUDNZD. Unique request ID: 96 | 2018-09-05 03:50:01 Removed historical data download ID 96 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for AUDNZD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\AUDNZD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for AUDNZD | 2018-09-05 03:50:01 HD Request # 91 | Downloading Intraday chart data for CADCHF to the file CADCHF.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 91 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 91 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: CADCHF | 2018-09-05 03:50:01 HD Request # 91 | Error downloading historical Intraday data for CADCHF. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 91 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CADCHF | 2018-09-05 03:50:01 HD Request # 91 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 91 | Intraday data download complete for CADCHF. Unique request ID: 97 | 2018-09-05 03:50:01 Removed historical data download ID 97 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for CADCHF | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\CADCHF.scid | 2018-09-05 03:50:01 Intraday chart data file opened for CADCHF | 2018-09-05 03:50:01 HD Request # 92 | Downloading Intraday chart data for HKG33 to the file HKG33.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 92 | Download start date-time: 2018-09-04 10:14:04.000 | 2018-09-05 03:50:01 HD Request # 92 | Sending historical data request. Start date-time: 2018-09-04 10:14:04. Record interval: 60. Symbol: HKG33 | 2018-09-05 03:50:01 HD Request # 92 | Error downloading historical Intraday data for HKG33. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 92 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HKG33 | 2018-09-05 03:50:01 HD Request # 92 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 92 | Intraday data download complete for HKG33. Unique request ID: 98 | 2018-09-05 03:50:01 Removed historical data download ID 98 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for HKG33 | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\HKG33.scid | 2018-09-05 03:50:01 Intraday chart data file opened for HKG33 | 2018-09-05 03:50:01 HD Request # 93 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 93 | Download start date-time: 2018-09-04 23:54:00.000 | 2018-09-05 03:50:01 HD Request # 93 | Sending historical data request. Start date-time: 2018-09-04 23:54:00. Record interval: 60. Symbol: AUDJPY | 2018-09-05 03:50:01 HD Request # 93 | Error downloading historical Intraday data for AUDJPY. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 93 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDJPY | 2018-09-05 03:50:01 HD Request # 93 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 93 | Intraday data download complete for AUDJPY. Unique request ID: 99 | 2018-09-05 03:50:01 Removed historical data download ID 99 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for AUDJPY | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\AUDJPY.scid | 2018-09-05 03:50:01 Intraday chart data file opened for AUDJPY | 2018-09-05 03:50:01 HD Request # 94 | Downloading Intraday chart data for EURCHF to the file EURCHF.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 94 | Download start date-time: 2018-09-04 23:53:58.000 | 2018-09-05 03:50:01 HD Request # 94 | Sending historical data request. Start date-time: 2018-09-04 23:53:58. Record interval: 60. Symbol: EURCHF | 2018-09-05 03:50:01 HD Request # 94 | Error downloading historical Intraday data for EURCHF. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 94 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURCHF | 2018-09-05 03:50:01 HD Request # 94 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 94 | Intraday data download complete for EURCHF. Unique request ID: 100 | 2018-09-05 03:50:01 Removed historical data download ID 100 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for EURCHF | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\EURCHF.scid | 2018-09-05 03:50:01 Intraday chart data file opened for EURCHF | 2018-09-05 03:50:01 HD Request # 95 | Downloading Intraday chart data for EURCAD to the file EURCAD.scid. Service: fxcm | 2018-09-05 03:50:01 HD Request # 95 | Download start date-time: 2018-09-04 23:53:01.000 | 2018-09-05 03:50:01 HD Request # 95 | Sending historical data request. Start date-time: 2018-09-04 23:53:01. Record interval: 60. Symbol: EURCAD | 2018-09-05 03:50:01 HD Request # 95 | Error downloading historical Intraday data for EURCAD. Historical data request rejected because the symbol is not valid | 2018-09-05 03:50:01 HD Request # 95 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EURCAD | 2018-09-05 03:50:01 HD Request # 95 | Completion time: 0s | 2018-09-05 03:50:01 HD Request # 95 | Intraday data download complete for EURCAD. Unique request ID: 101 | 2018-09-05 03:50:01 Removed historical data download ID 101 | 2018-09-05 03:50:01 Real-time Intraday chart data file updates started for EURCAD | 2018-09-05 03:50:01 Opened cached Intraday file: C:\SierraChart\Data\EURCAD.scid | 2018-09-05 03:50:01 Intraday chart data file opened for EURCAD | 2018-09-05 03:50:01 HD Request # 96 | Downloading Intraday chart data for ZFZ8-CBOT to the file ZFZ8-CBOT.scid. Service: cbot | 2018-09-05 03:50:04 HD Request # 96 | Download start date-time: 2018-09-05 03:49:05.000 | 2018-09-05 03:50:04 HD Request # 96 | Using server: ds7.sierracharts.com port 10149 | 2018-09-05 03:50:04 Socket (243) | Creating socket. | 2018-09-05 03:50:04 Socket (243) | Connecting to IP: 8.18.161.133. | 2018-09-05 03:50:04 HD Request # 96 | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:05 HD Request # 96 | Sending historical data logon request message. | 2018-09-05 03:50:05 HD Request # 96 | Requesting Intraday data. Start date-time: 2018-09-05 03:49:05. Record interval: 60. Symbol: ZFZ18 | 2018-09-05 03:50:05 HD Request # 96 | Decompressing data. | 2018-09-05 03:50:05 Socket (243) | Initiating close of socket by core. | 2018-09-05 03:50:05 Socket (243) | Shutdown started. Waiting for graceful close. | 2018-09-05 03:50:05 Historical data download thread signaled to stop. | 2018-09-05 03:50:05 HD Request # 96 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZFZ8-CBOT | 2018-09-05 03:50:05 HD Request # 96 | Completion time: 0s | 2018-09-05 03:50:05 HD Request # 96 | Intraday data download complete for ZFZ8-CBOT. Unique request ID: 61 | 2018-09-05 03:50:05 Removed historical data download ID 61 | 2018-09-05 03:50:05 Real-time Intraday chart data file updates started for ZFZ8-CBOT | 2018-09-05 03:50:05 Opened cached Intraday file: C:\SierraChart\Data\ZFZ8-CBOT.scid | 2018-09-05 03:50:05 Intraday chart data file opened for ZFZ8-CBOT | 2018-09-05 03:50:05 Rithmic Trading | Using primary service for historical data for ZFZ8-CBOT | 2018-09-05 03:50:05 Intraday data recording state for symbol ZFZ8-CBOT is set to download 'Pending'. | 2018-09-05 03:50:05 HD Request # 97 | Downloading Intraday chart data for ZFZ8-CBOT to the file ZFZ8-CBOT.scid. Service: rithmic.trading | 2018-09-05 03:50:05 HD Request # 97 | Download start date-time: 2018-09-05 03:49:05.000 | 2018-09-05 03:50:05 HD Request # 97 | Sending historical data request. Start date-time: 2018-09-05 03:49:05. Record interval: 60. Symbol: ZFZ8-CBOT | 2018-09-05 03:50:05 HD Request # 98 | Downloading Intraday chart data for YMU8-CBOT to the file YMU8-CBOT.scid. Service: cbot | 2018-09-05 03:50:05 HD Request # 98 | Download start date-time: 2018-09-05 03:49:02.000 | 2018-09-05 03:50:05 HD Request # 98 | Using server: ds1.sierracharts.com port 10150 | 2018-09-05 03:50:05 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2018-09-05 03:50:05 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-09-05 03:50:05 Socket (244) | Creating socket. | 2018-09-05 03:50:05 Socket (244) | Connecting to IP: 8.18.161.135. | 2018-09-05 03:50:05 Socket (243) | Socket gracefully closed by remote side. | 2018-09-05 03:50:05 Socket (243) | Closed. | 2018-09-05 03:50:05 HD Request # 97 | Receiving Intraday data for ZFZ8-CBOT starting at 2018-09-05 03:49:05 | 2018-09-05 03:50:05 HD Request # 97 | Timestamp of first Intraday data file record written: 2018-09-05 03:49:05 | 2018-09-05 03:50:05 HD Request # 97 | Received 7 records from 2018-09-05 03:49:05 to 2018-09-05 03:49:43 (38.0 seconds) and wrote 7 records for ZFZ8-CBOT | 2018-09-05 03:50:05 HD Request # 97 | Completion time: 1s | 2018-09-05 03:50:05 HD Request # 97 | Intraday data download complete for ZFZ8-CBOT. Unique request ID: 102 | 2018-09-05 03:50:05 Removed historical data download ID 102 | 2018-09-05 03:50:05 Real-time Intraday chart data file updates started for ZFZ8-CBOT | 2018-09-05 03:50:05 Opened cached Intraday file: C:\SierraChart\Data\ZFZ8-CBOT.scid | 2018-09-05 03:50:05 Intraday chart data file opened for ZFZ8-CBOT | 2018-09-05 03:50:05 HD Request # 98 | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:05 HD Request # 98 | Sending historical data logon request message. | 2018-09-05 03:50:05 HD Server | HD Request #13 | Socket: 242 | Symbol: ZFZ8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | Records Served: 1 | ClientRequestID: 13 | Username: namsom. | 2018-09-05 03:50:05 Socket (242) | Socket gracefully closed by remote side. | 2018-09-05 03:50:05 Socket (242) | Received socket Close event. | 2018-09-05 03:50:05 Socket (242) | Initiating close of socket by core. | 2018-09-05 03:50:05 Socket (242) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 03:50:05 Socket (242) | Closed. | 2018-09-05 03:50:05 HD Server | Server thread ending. Socket closed. | Username: namsom. | 2018-09-05 03:50:05 HD Server | New server thread for client has been created for incoming connection. | 2018-09-05 03:50:05 Socket (245) | Creating socket. | 2018-09-05 03:50:05 HD Server | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:05 HD Server | Received login. Requesting authorization. | Username: namsom. | 2018-09-05 03:50:05 HD Server | Login has been authorized. | Username: namsom. | 2018-09-05 03:50:05 HD Server | HD Request #14 | Socket: 245 | Symbol: ZNZ8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | MaximumDaysRequested: 0 | Start date-time: 2018-09-05 01:49:05 | ClientRequestID: 14 | Username: namsom. | 2018-09-05 03:50:05 HD Request # 98 | Requesting Intraday data. Start date-time: 2018-09-05 03:49:02. Record interval: 60. Symbol: YMU18 | 2018-09-05 03:50:05 HD Request # 98 | Decompressing data. | 2018-09-05 03:50:05 Socket (244) | Initiating close of socket by core. | 2018-09-05 03:50:05 Socket (244) | Shutdown started. Waiting for graceful close. | 2018-09-05 03:50:05 Historical data download thread signaled to stop. | 2018-09-05 03:50:05 HD Request # 98 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMU8-CBOT | 2018-09-05 03:50:05 HD Request # 98 | Completion time: 1s | 2018-09-05 03:50:05 HD Request # 98 | Intraday data download complete for YMU8-CBOT. Unique request ID: 65 | 2018-09-05 03:50:05 Removed historical data download ID 65 | 2018-09-05 03:50:05 Real-time Intraday chart data file updates started for YMU8-CBOT | 2018-09-05 03:50:05 Opened cached Intraday file: C:\SierraChart\Data\YMU8-CBOT.scid | 2018-09-05 03:50:05 Intraday chart data file opened for YMU8-CBOT | 2018-09-05 03:50:05 Rithmic Trading | Using primary service for historical data for YMU8-CBOT | 2018-09-05 03:50:05 Intraday data recording state for symbol YMU8-CBOT is set to download 'Pending'. | 2018-09-05 03:50:05 HD Request # 99 | Downloading Intraday chart data for YMU8-CBOT to the file YMU8-CBOT.scid. Service: rithmic.trading | 2018-09-05 03:50:05 HD Request # 99 | Download start date-time: 2018-09-05 03:49:02.000 | 2018-09-05 03:50:05 HD Request # 99 | Sending historical data request. Start date-time: 2018-09-05 03:49:02. Record interval: 60. Symbol: YMU8-CBOT | 2018-09-05 03:50:05 HD Request # 100 | Downloading Intraday chart data for ZNZ8-CBOT to the file ZNZ8-CBOT.scid. Service: cbot | 2018-09-05 03:50:05 HD Request # 100 | Download start date-time: 2018-09-05 03:49:05.000 | 2018-09-05 03:50:05 HD Request # 100 | Using server: ds7.sierracharts.com port 10149 | 2018-09-05 03:50:05 Socket (246) | Creating socket. | 2018-09-05 03:50:05 Socket (246) | Connecting to IP: 8.18.161.133. | 2018-09-05 03:50:05 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2018-09-05 03:50:05 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-09-05 03:50:05 Socket (244) | Socket gracefully closed by remote side. | 2018-09-05 03:50:06 Socket (244) | Closed. | 2018-09-05 03:50:06 HD Request # 100 | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:06 HD Request # 100 | Sending historical data logon request message. | 2018-09-05 03:50:06 HD Request # 99 | Receiving Intraday data for YMU8-CBOT starting at 2018-09-05 03:49:02 | 2018-09-05 03:50:06 HD Request # 99 | Timestamp of first Intraday data file record written: 2018-09-05 03:49:02 | 2018-09-05 03:50:06 HD Request # 99 | Received 30 records from 2018-09-05 03:49:02 to 2018-09-05 03:50:00 (58.0 seconds) and wrote 30 records for YMU8-CBOT | 2018-09-05 03:50:06 HD Request # 99 | Completion time: 0s | 2018-09-05 03:50:06 HD Request # 99 | Intraday data download complete for YMU8-CBOT. Unique request ID: 103 | 2018-09-05 03:50:06 Removed historical data download ID 103 | 2018-09-05 03:50:06 Real-time Intraday chart data file updates started for YMU8-CBOT | 2018-09-05 03:50:06 Opened cached Intraday file: C:\SierraChart\Data\YMU8-CBOT.scid | 2018-09-05 03:50:06 Intraday chart data file opened for YMU8-CBOT | 2018-09-05 03:50:06 HD Request # 100 | Requesting Intraday data. Start date-time: 2018-09-05 03:49:05. Record interval: 60. Symbol: ZNZ18 | 2018-09-05 03:50:06 HD Request # 100 | Decompressing data. | 2018-09-05 03:50:06 Socket (246) | Initiating close of socket by core. | 2018-09-05 03:50:06 Socket (246) | Shutdown started. Waiting for graceful close. | 2018-09-05 03:50:06 Historical data download thread signaled to stop. | 2018-09-05 03:50:06 HD Request # 100 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZNZ8-CBOT | 2018-09-05 03:50:06 HD Request # 100 | Completion time: 0s | 2018-09-05 03:50:06 HD Request # 100 | Intraday data download complete for ZNZ8-CBOT. Unique request ID: 69 | 2018-09-05 03:50:06 Removed historical data download ID 69 | 2018-09-05 03:50:06 Real-time Intraday chart data file updates started for ZNZ8-CBOT | 2018-09-05 03:50:06 Opened cached Intraday file: C:\SierraChart\Data\ZNZ8-CBOT.scid | 2018-09-05 03:50:06 Intraday chart data file opened for ZNZ8-CBOT | 2018-09-05 03:50:06 Rithmic Trading | Using primary service for historical data for ZNZ8-CBOT | 2018-09-05 03:50:06 Intraday data recording state for symbol ZNZ8-CBOT is set to download 'Pending'. | 2018-09-05 03:50:06 HD Request # 101 | Downloading Intraday chart data for ZNZ8-CBOT to the file ZNZ8-CBOT.scid. Service: rithmic.trading | 2018-09-05 03:50:06 HD Request # 101 | Download start date-time: 2018-09-05 03:49:05.000 | 2018-09-05 03:50:06 HD Request # 101 | Sending historical data request. Start date-time: 2018-09-05 03:49:05. Record interval: 60. Symbol: ZNZ8-CBOT | 2018-09-05 03:50:06 HD Request # 102 | Downloading Intraday chart data for CLV8-NYMEX to the file CLV8-NYMEX.scid. Service: nymex | 2018-09-05 03:50:06 HD Request # 102 | Download start date-time: 2018-09-05 03:49:00.000 | 2018-09-05 03:50:06 HD Request # 102 | Using server: ds1.sierracharts.com port 10150 | 2018-09-05 03:50:06 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2018-09-05 03:50:06 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-09-05 03:50:06 Socket (247) | Creating socket. | 2018-09-05 03:50:06 Socket (247) | Connecting to IP: 8.18.161.135. | 2018-09-05 03:50:06 Socket (246) | Socket gracefully closed by remote side. | 2018-09-05 03:50:06 Socket (246) | Closed. | 2018-09-05 03:50:06 HD Request # 102 | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:06 HD Request # 102 | Sending historical data logon request message. | 2018-09-05 03:50:06 HD Request # 101 | Receiving Intraday data for ZNZ8-CBOT starting at 2018-09-05 03:49:05 | 2018-09-05 03:50:06 HD Request # 101 | Timestamp of first Intraday data file record written: 2018-09-05 03:49:05 | 2018-09-05 03:50:06 HD Request # 101 | Received 157 records from 2018-09-05 03:49:05 to 2018-09-05 03:49:54 (49.0 seconds) and wrote 157 records for ZNZ8-CBOT | 2018-09-05 03:50:06 HD Request # 101 | Completion time: 1s | 2018-09-05 03:50:06 HD Request # 101 | Intraday data download complete for ZNZ8-CBOT. Unique request ID: 104 | 2018-09-05 03:50:06 Removed historical data download ID 104 | 2018-09-05 03:50:06 Real-time Intraday chart data file updates started for ZNZ8-CBOT | 2018-09-05 03:50:06 Opened cached Intraday file: C:\SierraChart\Data\ZNZ8-CBOT.scid | 2018-09-05 03:50:06 Intraday chart data file opened for ZNZ8-CBOT | 2018-09-05 03:50:06 HD Request # 102 | Requesting Intraday data. Start date-time: 2018-09-05 03:49:00. Record interval: 60. Symbol: CLV18 | 2018-09-05 03:50:06 HD Server | HD Request #14 | Socket: 245 | Symbol: ZNZ8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | Records Served: 1 | ClientRequestID: 14 | Username: namsom. | 2018-09-05 03:50:06 Socket (245) | Socket gracefully closed by remote side. | 2018-09-05 03:50:06 Socket (245) | Received socket Close event. | 2018-09-05 03:50:06 Socket (245) | Initiating close of socket by core. | 2018-09-05 03:50:06 Socket (245) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 03:50:06 Socket (245) | Closed. | 2018-09-05 03:50:06 HD Server | Server thread ending. Socket closed. | Username: namsom. | 2018-09-05 03:50:06 HD Server | New server thread for client has been created for incoming connection. | 2018-09-05 03:50:06 Socket (248) | Creating socket. | 2018-09-05 03:50:06 HD Server | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:06 HD Server | Received login. Requesting authorization. | Username: namsom. | 2018-09-05 03:50:06 HD Server | Login has been authorized. | Username: namsom. | 2018-09-05 03:50:06 HD Server | HD Request #15 | Socket: 248 | Symbol: ZBZ8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | MaximumDaysRequested: 0 | Start date-time: 2018-09-05 01:49:05 | ClientRequestID: 15 | Username: namsom. | 2018-09-05 03:50:06 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZBZ8-CBOT | 2018-09-05 03:50:06 Intraday data recording state for symbol ZBZ8-CBOT is set to download 'Pending'. | 2018-09-05 03:50:06 HD Request # 102 | Decompressing data. | 2018-09-05 03:50:06 Socket (247) | Initiating close of socket by core. | 2018-09-05 03:50:06 Socket (247) | Shutdown started. Waiting for graceful close. | 2018-09-05 03:50:06 Historical data download thread signaled to stop. | 2018-09-05 03:50:06 HD Request # 102 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLV8-NYMEX | 2018-09-05 03:50:06 HD Request # 102 | Completion time: 0s | 2018-09-05 03:50:06 HD Request # 102 | Intraday data download complete for CLV8-NYMEX. Unique request ID: 95 | 2018-09-05 03:50:06 Removed historical data download ID 95 | 2018-09-05 03:50:06 Real-time Intraday chart data file updates started for CLV8-NYMEX | 2018-09-05 03:50:06 Opened cached Intraday file: C:\SierraChart\Data\CLV8-NYMEX.scid | 2018-09-05 03:50:06 Intraday chart data file opened for CLV8-NYMEX | 2018-09-05 03:50:06 Rithmic Trading | Using primary service for historical data for CLV8-NYMEX | 2018-09-05 03:50:06 Intraday data recording state for symbol CLV8-NYMEX is set to download 'Pending'. | 2018-09-05 03:50:06 HD Request # 103 | Downloading Intraday chart data for CLV8-NYMEX to the file CLV8-NYMEX.scid. Service: rithmic.trading | 2018-09-05 03:50:06 HD Request # 103 | Download start date-time: 2018-09-05 03:49:00.000 | 2018-09-05 03:50:06 HD Request # 103 | Sending historical data request. Start date-time: 2018-09-05 03:49:00. Record interval: 60. Symbol: CLV8-NYMEX | 2018-09-05 03:50:06 HD Request # 104 | Downloading Intraday chart data for ZBZ8-CBOT to the file ZBZ8-CBOT.scid. Service: cbot | 2018-09-05 03:50:06 HD Request # 104 | Download start date-time: 2018-09-05 03:49:05.000 | 2018-09-05 03:50:06 HD Request # 104 | Using server: ds7.sierracharts.com port 10149 | 2018-09-05 03:50:06 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2018-09-05 03:50:06 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-09-05 03:50:06 Socket (249) | Creating socket. | 2018-09-05 03:50:06 Socket (249) | Connecting to IP: 8.18.161.133. | 2018-09-05 03:50:06 Socket (247) | Socket gracefully closed by remote side. | 2018-09-05 03:50:07 Socket (247) | Closed. | 2018-09-05 03:50:07 HD Request # 104 | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:07 HD Request # 104 | Sending historical data logon request message. | 2018-09-05 03:50:07 HD Request # 103 | Receiving Intraday data for CLV8-NYMEX starting at 2018-09-05 03:49:00 | 2018-09-05 03:50:07 HD Request # 103 | Timestamp of first Intraday data file record written: 2018-09-05 03:49:00 | 2018-09-05 03:50:07 HD Request # 103 | Received 73 records from 2018-09-05 03:49:00 to 2018-09-05 03:49:57 (57.0 seconds) and wrote 73 records for CLV8-NYMEX | 2018-09-05 03:50:07 HD Request # 103 | Completion time: 0s | 2018-09-05 03:50:07 HD Request # 103 | Intraday data download complete for CLV8-NYMEX. Unique request ID: 106 | 2018-09-05 03:50:07 Removed historical data download ID 106 | 2018-09-05 03:50:07 Real-time Intraday chart data file updates started for CLV8-NYMEX | 2018-09-05 03:50:07 Opened cached Intraday file: C:\SierraChart\Data\CLV8-NYMEX.scid | 2018-09-05 03:50:07 Intraday chart data file opened for CLV8-NYMEX | 2018-09-05 03:50:07 HD Request # 104 | Requesting Intraday data. Start date-time: 2018-09-05 03:49:05. Record interval: 60. Symbol: ZBZ18 | 2018-09-05 03:50:07 HD Request # 104 | Decompressing data. | 2018-09-05 03:50:07 Socket (249) | Initiating close of socket by core. | 2018-09-05 03:50:07 Socket (249) | Shutdown started. Waiting for graceful close. | 2018-09-05 03:50:07 Historical data download thread signaled to stop. | 2018-09-05 03:50:07 HD Request # 104 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZBZ8-CBOT | 2018-09-05 03:50:07 HD Request # 104 | Completion time: 0s | 2018-09-05 03:50:07 HD Request # 104 | Intraday data download complete for ZBZ8-CBOT. Unique request ID: 105 | 2018-09-05 03:50:07 Removed historical data download ID 105 | 2018-09-05 03:50:07 Real-time Intraday chart data file updates started for ZBZ8-CBOT | 2018-09-05 03:50:07 Opened cached Intraday file: C:\SierraChart\Data\ZBZ8-CBOT.scid | 2018-09-05 03:50:07 Intraday chart data file opened for ZBZ8-CBOT | 2018-09-05 03:50:07 Rithmic Trading | Using primary service for historical data for ZBZ8-CBOT | 2018-09-05 03:50:07 Intraday data recording state for symbol ZBZ8-CBOT is set to download 'Pending'. | 2018-09-05 03:50:07 HD Request # 105 | Downloading Intraday chart data for ZBZ8-CBOT to the file ZBZ8-CBOT.scid. Service: rithmic.trading | 2018-09-05 03:50:07 HD Request # 105 | Download start date-time: 2018-09-05 03:49:05.000 | 2018-09-05 03:50:07 HD Request # 105 | Sending historical data request. Start date-time: 2018-09-05 03:49:05. Record interval: 60. Symbol: ZBZ8-CBOT | 2018-09-05 03:50:07 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2018-09-05 03:50:07 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-09-05 03:50:07 Socket (249) | Socket gracefully closed by remote side. | 2018-09-05 03:50:07 Socket (249) | Closed. | 2018-09-05 03:50:07 HD Request # 105 | Receiving Intraday data for ZBZ8-CBOT starting at 2018-09-05 03:49:05 | 2018-09-05 03:50:07 HD Request # 105 | Timestamp of first Intraday data file record written: 2018-09-05 03:49:05 | 2018-09-05 03:50:07 HD Request # 105 | Received 31 records from 2018-09-05 03:49:05 to 2018-09-05 03:49:27 (22.0 seconds) and wrote 31 records for ZBZ8-CBOT | 2018-09-05 03:50:07 HD Request # 105 | Completion time: 1s | 2018-09-05 03:50:07 HD Request # 105 | Intraday data download complete for ZBZ8-CBOT. Unique request ID: 107 | 2018-09-05 03:50:07 Removed historical data download ID 107 | 2018-09-05 03:50:07 Real-time Intraday chart data file updates started for ZBZ8-CBOT | 2018-09-05 03:50:07 Opened cached Intraday file: C:\SierraChart\Data\ZBZ8-CBOT.scid | 2018-09-05 03:50:07 Intraday chart data file opened for ZBZ8-CBOT | 2018-09-05 03:50:07 HD Server | HD Request #15 | Socket: 248 | Symbol: ZBZ8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | Records Served: 1 | ClientRequestID: 15 | Username: namsom. | 2018-09-05 03:50:07 Socket (248) | Socket gracefully closed by remote side. | 2018-09-05 03:50:07 Socket (248) | Initiating close of socket by core. | 2018-09-05 03:50:07 Socket (248) | Received socket Close event. | 2018-09-05 03:50:07 Socket (248) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 03:50:07 Socket (248) | Closed. | 2018-09-05 03:50:07 HD Server | Server thread ending. Socket closed. | Username: namsom. | 2018-09-05 03:50:07 HD Server | New server thread for client has been created for incoming connection. | 2018-09-05 03:50:07 Socket (250) | Creating socket. | 2018-09-05 03:50:07 HD Server | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:07 HD Server | Received login. Requesting authorization. | Username: namsom. | 2018-09-05 03:50:07 HD Server | Login has been authorized. | Username: namsom. | 2018-09-05 03:50:07 HD Server | HD Request #16 | Socket: 250 | Symbol: NGV8-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 60 | MaximumDaysRequested: 0 | Start date-time: 2018-09-05 01:49:19 | ClientRequestID: 16 | Username: namsom. | 2018-09-05 03:50:07 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGV8-NYMEX | 2018-09-05 03:50:07 Intraday data recording state for symbol NGV8-NYMEX is set to download 'Pending'. | 2018-09-05 03:50:07 HD Request # 106 | Downloading Intraday chart data for NGV8-NYMEX to the file NGV8-NYMEX.scid. Service: nymex | 2018-09-05 03:50:07 HD Request # 106 | Download start date-time: 2018-09-05 03:49:19.000 | 2018-09-05 03:50:07 HD Request # 106 | Using server: ds1.sierracharts.com port 10150 | 2018-09-05 03:50:07 Socket (251) | Creating socket. | 2018-09-05 03:50:07 Socket (251) | Connecting to IP: 8.18.161.135. | 2018-09-05 03:50:07 HD Request # 106 | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:08 HD Request # 106 | Sending historical data logon request message. | 2018-09-05 03:50:08 HD Request # 106 | Requesting Intraday data. Start date-time: 2018-09-05 03:49:19. Record interval: 60. Symbol: NGV18 | 2018-09-05 03:50:08 HD Request # 106 | Decompressing data. | 2018-09-05 03:50:08 Socket (251) | Initiating close of socket by core. | 2018-09-05 03:50:08 Socket (251) | Shutdown started. Waiting for graceful close. | 2018-09-05 03:50:08 Historical data download thread signaled to stop. | 2018-09-05 03:50:08 HD Request # 106 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NGV8-NYMEX | 2018-09-05 03:50:08 HD Request # 106 | Completion time: 0s | 2018-09-05 03:50:08 HD Request # 106 | Intraday data download complete for NGV8-NYMEX. Unique request ID: 108 | 2018-09-05 03:50:08 Removed historical data download ID 108 | 2018-09-05 03:50:08 Real-time Intraday chart data file updates started for NGV8-NYMEX | 2018-09-05 03:50:08 Opened cached Intraday file: C:\SierraChart\Data\NGV8-NYMEX.scid | 2018-09-05 03:50:08 Intraday chart data file opened for NGV8-NYMEX | 2018-09-05 03:50:08 Rithmic Trading | Using primary service for historical data for NGV8-NYMEX | 2018-09-05 03:50:08 Intraday data recording state for symbol NGV8-NYMEX is set to download 'Pending'. | 2018-09-05 03:50:08 HD Request # 107 | Downloading Intraday chart data for NGV8-NYMEX to the file NGV8-NYMEX.scid. Service: rithmic.trading | 2018-09-05 03:50:08 HD Request # 107 | Download start date-time: 2018-09-05 03:49:19.000 | 2018-09-05 03:50:08 HD Request # 107 | Sending historical data request. Start date-time: 2018-09-05 03:49:19. Record interval: 60. Symbol: NGV8-NYMEX | 2018-09-05 03:50:08 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2018-09-05 03:50:08 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-09-05 03:50:08 Socket (251) | Socket gracefully closed by remote side. | 2018-09-05 03:50:08 Socket (251) | Closed. | 2018-09-05 03:50:08 HD Request # 107 | Receiving Intraday data for NGV8-NYMEX starting at 2018-09-05 03:49:19 | 2018-09-05 03:50:08 HD Request # 107 | Timestamp of first Intraday data file record written: 2018-09-05 03:49:19 | 2018-09-05 03:50:08 HD Request # 107 | Received 1 record from 2018-09-05 03:49:19 to 2018-09-05 03:49:19 (0.0 seconds) and wrote 1 record for NGV8-NYMEX | 2018-09-05 03:50:08 HD Request # 107 | Completion time: 1s | 2018-09-05 03:50:08 HD Request # 107 | Intraday data download complete for NGV8-NYMEX. Unique request ID: 109 | 2018-09-05 03:50:08 Removed historical data download ID 109 | 2018-09-05 03:50:08 Real-time Intraday chart data file updates started for NGV8-NYMEX | 2018-09-05 03:50:08 Opened cached Intraday file: C:\SierraChart\Data\NGV8-NYMEX.scid | 2018-09-05 03:50:08 Intraday chart data file opened for NGV8-NYMEX | 2018-09-05 03:50:08 HD Server | HD Request #16 | Socket: 250 | Symbol: NGV8-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 60 | Records Served: 1 | ClientRequestID: 16 | Username: namsom. | 2018-09-05 03:50:08 Socket (250) | Socket gracefully closed by remote side. | 2018-09-05 03:50:08 Socket (250) | Received socket Close event. | 2018-09-05 03:50:08 Socket (250) | Initiating close of socket by core. | 2018-09-05 03:50:08 Socket (250) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 03:50:08 Socket (250) | Closed. | 2018-09-05 03:50:08 HD Server | Server thread ending. Socket closed. | Username: namsom. | 2018-09-05 03:50:08 HD Server | New server thread for client has been created for incoming connection. | 2018-09-05 03:50:08 Socket (252) | Creating socket. | 2018-09-05 03:50:08 HD Server | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:08 HD Server | Received login. Requesting authorization. | Username: namsom. | 2018-09-05 03:50:08 HD Server | Login has been authorized. | Username: namsom. | 2018-09-05 03:50:08 HD Server | HD Request #17 | Socket: 252 | Symbol: CLV8-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 60 | MaximumDaysRequested: 0 | Start date-time: 2018-09-05 01:49:00 | ClientRequestID: 17 | Username: namsom. | 2018-09-05 03:50:08 HD Server | HD Request #17 | Socket: 252 | Symbol: CLV8-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 60 | Records Served: 1 | ClientRequestID: 17 | Username: namsom. | 2018-09-05 03:50:08 Socket (252) | Socket gracefully closed by remote side. | 2018-09-05 03:50:08 Socket (252) | Received socket Close event. | 2018-09-05 03:50:08 Socket (252) | Initiating close of socket by core. | 2018-09-05 03:50:08 Socket (252) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 03:50:08 Socket (252) | Closed. | 2018-09-05 03:50:08 HD Server | Server thread ending. Socket closed. | Username: namsom. | 2018-09-05 03:50:08 HD Server | New server thread for client has been created for incoming connection. | 2018-09-05 03:50:09 Socket (253) | Creating socket. | 2018-09-05 03:50:08 HD Server | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:09 HD Server | Received login. Requesting authorization. | Username: namsom. | 2018-09-05 03:50:09 HD Server | Login has been authorized. | Username: namsom. | 2018-09-05 03:50:09 HD Server | HD Request #18 | Socket: 253 | Symbol: YMU8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | MaximumDaysRequested: 0 | Start date-time: 2018-09-05 01:49:02 | ClientRequestID: 18 | Username: namsom. | 2018-09-05 03:50:09 HD Server | HD Request #18 | Socket: 253 | Symbol: YMU8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | Records Served: 2 | ClientRequestID: 18 | Username: namsom. | 2018-09-05 03:50:09 Socket (253) | Socket gracefully closed by remote side. | 2018-09-05 03:50:08 Socket (253) | Received socket Close event. | 2018-09-05 03:50:08 Socket (253) | Initiating close of socket by core. | 2018-09-05 03:50:09 Socket (253) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 03:50:08 Socket (253) | Closed. | 2018-09-05 03:50:08 HD Server | Server thread ending. Socket closed. | Username: namsom. | 2018-09-05 03:50:09 HD Server | New server thread for client has been created for incoming connection. | 2018-09-05 03:50:09 Socket (254) | Creating socket. | 2018-09-05 03:50:09 HD Server | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:09 HD Server | Received login. Requesting authorization. | Username: namsom. | 2018-09-05 03:50:09 HD Server | Login has been authorized. | Username: namsom. | 2018-09-05 03:50:09 HD Server | HD Request #19 | Socket: 254 | Symbol: UBZ8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | MaximumDaysRequested: 0 | Start date-time: 2018-09-05 01:49:05 | ClientRequestID: 19 | Username: namsom. | 2018-09-05 03:50:09 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: UBZ8-CBOT | 2018-09-05 03:50:09 Intraday data recording state for symbol UBZ8-CBOT is set to download 'Pending'. | 2018-09-05 03:50:09 HD Request # 108 | Downloading Intraday chart data for UBZ8-CBOT to the file UBZ8-CBOT.scid. Service: cbot | 2018-09-05 03:50:09 HD Request # 108 | Download start date-time: 2018-09-05 03:49:05.000 | 2018-09-05 03:50:09 HD Request # 108 | Using server: ds7.sierracharts.com port 10149 | 2018-09-05 03:50:09 Socket (255) | Creating socket. | 2018-09-05 03:50:09 Socket (255) | Connecting to IP: 8.18.161.133. | 2018-09-05 03:50:09 HD Request # 108 | Setting DTC encoding to Binary VLS | 2018-09-05 03:50:09 HD Request # 108 | Sending historical data logon request message. | 2018-09-05 03:50:09 HD Request # 108 | Requesting Intraday data. Start date-time: 2018-09-05 03:49:05. Record interval: 60. Symbol: UBZ18 | 2018-09-05 03:50:09 HD Request # 108 | Decompressing data. | 2018-09-05 03:50:09 Socket (255) | Initiating close of socket by core. | 2018-09-05 03:50:09 Socket (255) | Shutdown started. Waiting for graceful close. | 2018-09-05 03:50:09 Historical data download thread signaled to stop. | 2018-09-05 03:50:09 HD Request # 108 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for UBZ8-CBOT | 2018-09-05 03:50:09 HD Request # 108 | Completion time: 0s | 2018-09-05 03:50:09 HD Request # 108 | Intraday data download complete for UBZ8-CBOT. Unique request ID: 110 | 2018-09-05 03:50:09 Removed historical data download ID 110 | 2018-09-05 03:50:09 Real-time Intraday chart data file updates started for UBZ8-CBOT | 2018-09-05 03:50:09 Opened cached Intraday file: C:\SierraChart\Data\UBZ8-CBOT.scid | 2018-09-05 03:50:09 Intraday chart data file opened for UBZ8-CBOT | 2018-09-05 03:50:09 Rithmic Trading | Using primary service for historical data for UBZ8-CBOT | 2018-09-05 03:50:09 Intraday data recording state for symbol UBZ8-CBOT is set to download 'Pending'. | 2018-09-05 03:50:09 HD Request # 109 | Downloading Intraday chart data for UBZ8-CBOT to the file UBZ8-CBOT.scid. Service: rithmic.trading | 2018-09-05 03:50:09 HD Request # 109 | Download start date-time: 2018-09-05 03:49:05.000 | 2018-09-05 03:50:09 HD Request # 109 | Sending historical data request. Start date-time: 2018-09-05 03:49:05. Record interval: 60. Symbol: UBZ8-CBOT | 2018-09-05 03:50:09 Rithmic Trading | Message from server: Setting record interval to 1 tick. | 2018-09-05 03:50:09 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-09-05 03:50:09 Socket (255) | Socket gracefully closed by remote side. | 2018-09-05 03:50:09 Socket (255) | Closed. | 2018-09-05 03:50:09 HD Request # 109 | Receiving Intraday data for UBZ8-CBOT starting at 2018-09-05 03:49:05 | 2018-09-05 03:50:09 HD Request # 109 | Timestamp of first Intraday data file record written: 2018-09-05 03:49:05 | 2018-09-05 03:50:09 HD Request # 109 | Received 46 records from 2018-09-05 03:49:05 to 2018-09-05 03:49:41 (36.0 seconds) and wrote 46 records for UBZ8-CBOT | 2018-09-05 03:50:09 HD Request # 109 | Completion time: 0s | 2018-09-05 03:50:09 HD Request # 109 | Intraday data download complete for UBZ8-CBOT. Unique request ID: 111 | 2018-09-05 03:50:09 Removed historical data download ID 111 | 2018-09-05 03:50:09 Real-time Intraday chart data file updates started for UBZ8-CBOT | 2018-09-05 03:50:09 Opened cached Intraday file: C:\SierraChart\Data\UBZ8-CBOT.scid | 2018-09-05 03:50:09 Intraday chart data file opened for UBZ8-CBOT | 2018-09-05 03:50:09 HD Server | HD Request #19 | Socket: 254 | Symbol: UBZ8-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 60 | Records Served: 1 | ClientRequestID: 19 | Username: namsom. | 2018-09-05 03:50:10 Socket (254) | Socket gracefully closed by remote side. | 2018-09-05 03:50:10 Socket (254) | Received socket Close event. | 2018-09-05 03:50:10 Socket (254) | Initiating close of socket by core. | 2018-09-05 03:50:10 Socket (254) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-05 03:50:10 Socket (254) | Closed. | 2018-09-05 03:50:10 HD Server | Server thread ending. Socket closed. | Username: namsom. | 2018-09-05 03:50:10 Chart Symbols I have a problem e.g. GBPUSD EURJPY |
[2018-09-05 02:42:55] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
