Date/Time: Wed, 22 Jan 2025 04:13:32 +0000
Control Bar
View Count: 561
[2018-09-04 19:52:48] |
User750920 - Posts: 280 |
Is it possible to have a control bar on a detached window. So that I can change the periodicity or whatever from the control bar for that specific chart without having to go into the menu system.
[2018-09-04 20:21:03] |
Yes. Refer to: Control Bar: Window >> Control Bars >> Control Bar [1-12] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
