Date/Time: Wed, 22 Jan 2025 04:32:17 +0000
Cannot connect to CTS T4 FIX
View Count: 871
[2018-09-04 17:16:38]
Meritus - Posts: 164
Please advise, I am trying unsuccessfully to connect to CTS T4 FIX but SC says Not Connected. I am not sure what if anything Im doing wrong. My broker AMP say they have enabled SC on my account and I have entered my CTS login details in the Data Trade Service Settings but no connection. Please help. I have sent you the log files
CTS FIX socket (8) | Creating socket. Using TLS 1.0. | 2018-09-04 16:35:22
CTS FIX socket (8) | Connecting to IP: 74.201.6.106. | 2018-09-04 16:35:22
CTS FIX: Sending the Logon message. | 2018-09-04 16:35:22
CTS FIX socket (8) | Socket gracefully closed by remote side. | 2018-09-04 16:35:23
CTS FIX socket (8) | Received socket Close event. | 2018-09-04 16:35:23
CTS FIX: Received a Logout message. Text = Undetermined | 2018-09-04 16:35:23
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-09-04 16:35:23
CTS FIX socket (8) | Initiating close of socket by core. | 2018-09-04 16:35:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-04 16:35:23
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-04 16:35:23
CTS FIX socket (8) | Write in progress. Shutdown being delayed. | 2018-09-04 16:35:23
CTS T4 FIX | Disconnected. | 2018-09-04 16:35:23
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-04 16:35:23
CTS FIX socket (8) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-04 16:35:23 *
CTS FIX socket (8) | Write has completed. Shutdown being performed. | 2018-09-04 16:35:23
CTS FIX socket (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-04 16:35:23
CTS FIX socket (8) | Closed. | 2018-09-04 16:35:23
CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-09-04 16:35:26
CTS T4 FIX | Firm: AMP | 2018-09-04 16:35:26
CTS FIX socket (9) | Creating socket. Using TLS 1.0. | 2018-09-04 16:35:26
CTS FIX socket (9) | Connecting to IP: 74.201.6.106. | 2018-09-04 16:35:26
CTS FIX: Sending the Logon message. | 2018-09-04 16:35:26
CTS FIX: Received a Logout message. Text = Undetermined | 2018-09-04 16:35:26
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-09-04 16:35:26
CTS FIX socket (9) | Initiating close of socket by core. | 2018-09-04 16:35:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-04 16:35:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-04 16:35:26
CTS FIX socket (9) | Write in progress. Shutdown being delayed. | 2018-09-04 16:35:26
CTS FIX socket (9) | Socket gracefully closed by remote side. | 2018-09-04 16:35:26
CTS FIX socket (9) | Received socket Close event. | 2018-09-04 16:35:26
CTS T4 FIX | Disconnected. | 2018-09-04 16:35:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-04 16:35:26
CTS FIX socket (9) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-04 16:35:27 *
CTS FIX socket (9) | Write has completed. Shutdown being performed. | 2018-09-04 16:35:27
CTS FIX socket (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-04 16:35:27
CTS FIX socket (9) | Closed. | 2018-09-04 16:35:27
CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-09-04 16:35:29
CTS T4 FIX | Firm: AMP | 2018-09-04 16:35:29
CTS FIX socket (10) | Creating socket. Using TLS 1.0. | 2018-09-04 16:35:30
CTS FIX socket (10) | Connecting to IP: 69.44.110.74. | 2018-09-04 16:35:30
CTS FIX: Sending the Logon message. | 2018-09-04 16:35:31
CTS FIX socket (10) | Socket gracefully closed by remote side. | 2018-09-04 16:35:31
CTS FIX socket (10) | Received socket Close event. | 2018-09-04 16:35:31
CTS FIX: Received a Logout message. Text = Undetermined | 2018-09-04 16:35:31
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-09-04 16:35:31
CTS FIX socket (10) | Initiating close of socket by core. | 2018-09-04 16:35:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-04 16:35:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-04 16:35:31
CTS FIX socket (10) | Write in progress. Shutdown being delayed. | 2018-09-04 16:35:31
CTS T4 FIX | Disconnected. | 2018-09-04 16:35:31
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-04 16:35:31
CTS FIX socket (10) | Write has completed. Shutdown being performed. | 2018-09-04 16:35:31
CTS FIX socket (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-04 16:35:31
CTS FIX socket (10) | Closed. | 2018-09-04 16:35:31
File >> Disconnect selected. | 2018-09-04 16:35:32
CTS T4 FIX | Disconnected. | 2018-09-04 16:35:32
[2018-09-04 18:23:01]
Thinking about this, it is going to most efficient if you contact CTS directly:
http://www.ctsfutures.com/
Let them know you are getting this message:
Provide them these details along with your CTS username:
In general this is a matter between you, CTS and your broker. It would be rare that we would need to be involved in a connection issue like this.
Date Time Of Last Edit: 2018-09-04 20:24:49
