Date/Time: Wed, 22 Jan 2025 04:26:58 +0000
SC messed up when cleaning up disk
View Count: 699
[2018-09-04 15:02:42] |
User40526 - Posts: 166 |
I was low on disk space this morning and cleaned up my disk with "disk clean up." I cleaned up the disk first, then system files. I also deleted a program that I don't use on this computer as I want it to only handle SC. Now my charts are messed up and, while I'm willing to take the time to rebuild them, I see that my computer clock and the clock on my SC application to not agree. I am not tech savvy enough to figure out the problem. It is currently flattening my positions and SC has the time as 3PM Central and it is actually 10am. I also and not savvy enough to follow your instructions on providing a screen shot, which I tried to do. By the way, I regularly compress my data to 30 days and 1 minute, usually every couple of days to maintain disk space. Please help. Thanks |
[2018-09-04 17:17:34] |
Now my charts are messed up We do not know what this means. You may want to access a backup Chartbook:Chartbooks (Workspaces): Accessing a Backup Chartbook File I see that my computer clock and the clock on my SC application to not agree. Refer to help topic 38 for instructions to set the computer clock including the time zone:Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
