Date/Time: Sun, 24 Nov 2024 09:48:35 +0000
Mouse & drawing tools disconnect
View Count: 1519
[2013-10-23 15:05:06]
Joseph T. Carroll - Posts: 4
This is getting very frustrating. My mouse is sometimes 1/4 to 1/2 inch away from drawing, very hard to control where the drawing goes, as if it had a mind of it's own.
Date Time Of Last Edit: 2013-10-23 17:50:40
[2013-10-23 17:49:56]
If you are referring to the vertical position, then do the following:
Uncheck the Tools >> Auto Snap options which are documented here:
https://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Snapping
Disable Chart >> Chart Settings >> Advanced Settings >> Adjust Tool Values to Tick Size. It is also possible you do not have the proper Tick Size set.
[2013-10-23 18:23:25]
No I'm referring to trying to dray trend lines on an angle.
[2013-10-23 18:39:30]
The settings we referred to in the prior post, should resolve the problem.
