Date/Time: Wed, 22 Jan 2025 04:38:08 +0000
Cost of the Platform in case I would like to install it on more than 2 Computer Systems
View Count: 718
[2018-09-04 07:26:02] |
Tradix10 - Posts: 3 |
Hello, what are the monthly cost for SC SP5 in case I would like to install and use SC on more than 2 PCs? Is there also a discount plan in place? (3/ 6 / 12 Months prescription) ? Thank You! |
[2018-09-04 17:58:07] |
The pricing for that is here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#3 This is to the section where you can activate additional systems. It is 8 USD/month per system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-04 17:58:52
