Date/Time: Wed, 22 Jan 2025 04:29:30 +0000
Copy Chart Drawings problem
View Count: 1053
[2018-09-04 03:51:50] |
Meklon - Posts: 220 |
Hello support, I have observed this problem for quite a while (at least past 6 months) and tried to identify the reason but so far was unsuccessful. When Chart has a drawing (i.e. "Extending Rectangle Tool") copied from another chat it works fine. However, when you change (or roll over) futures symbol on the source chart, the chart these objects projected on still displays the original lines and they overlap with a new objects (displayed based on the new symbol). If I remove the old projected drawings manually, the chart looks ok and only displays new drawings, but if I leave them in place they overlapping with what the current symbol drawing projecting. Is this a bug, or there some settings that I am missing? Thanks. Date Time Of Last Edit: 2020-08-14 03:36:22
[2018-09-04 04:26:16] |
This is explained here: Chart Drawing Tools: Showing or Hiding Drawings for Different Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-04 04:53:43] |
I am failing to find "Show Chart Drawings for Different Symbols" option on the Chart Settings interface. Could you please be more specific? Where exactly this option is located, Main Settings, Advanced Settings, Advanced Settings 2 or Advanced Settings 3?
[2018-09-04 05:07:07] |
The documentation has now been updated. It is on Advanced Settings 2.
