Date/Time: Sun, 24 Nov 2024 09:46:30 +0000
Custom study cpp trouble
View Count: 1815
[2013-10-23 14:38:10]
User66360 - Posts: 81
I am trying to add a custom study that I got. When I try to add it , I keep getting a Source file "named here" is missing. What am I doing wrong? Please help, thanks
imageCapture.PNG / V - Attached On 2013-10-23 14:37:04 UTC - Size: 47.92 KB - 443 views
[2013-10-23 15:35:11]
Sierra Chart - Max - Posts: 5730
Where is the .cpp file located?
It should be in the ACS_Source folder within your Sierra Chart installation folder.
Please refer to the step by step instructions here:
http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html#Instructions
Sierra Chart Support
Date Time Of Last Edit: 2013-10-23 15:35:24
[2013-10-23 19:16:16]
I put the file in the ACS_Source folder, its not showing up in the steps when I go to analysis, build custom studies DLL.
Its in there when I open the Sierra Charts , ACS_Source. I see it, its right there. But not when I do the steps above????
Getting frustrated, Please help..... Thanks in advance
